Here’s some more details.
Factory reset router.
System > Reset Configuration ( All Default ) > Reset Configuration
First time Login I reset admin password
I’ve updated routerOS
System > Packages > Check for Updates
Current version : hAP ax S / 7.21.1 (stable)
Made a config backup
Files > Backup ( Set new name, don’t encrypt ( This saves a lot of time when I want to start over ))
I think I may have explained myself incorrectly, I want to access my phones wifi and share that connection from the router’s own ap, not a repeater. I hope I explained that correctly.
From this vanilla config I have tried.
Quick Set
the quick set menu has 1 option “Home AP Dual” I thought there might of been some other options in there that matched my goals but no such luck
A google search has lead me to many similar guides, I will link this one for its detail and clarity.
https://www.makeitcloudy.pl/how-to-configure-mikrotik-as-wifi-client-with-iphone-hotspot/
Exclude the Wi-Fi interface from the bridge - Bridge -> Ports -> Delete the Wi-Fi interface (wlan1)
Include the Ether1 interface in the bridge - Bridge - Ports -> Open ether5 -> Copy -> Change the interface in the new dialog to ether 1 -> OK (this will cause that all your ethernet ports can be used to connect devices, with stock configuration the ether1 is being used as the uplink) - within our scenario we use the wlan1 as the uplink
Adjust which is the WAN port - Interfaces -> Interface list - WAN -> wlan1 (with stock it is ether1, it needs to be changed for the wlan1, as it plays the uplink role) Wireless -> WiFi interfaces -> wlan1 -> Mode - Station
Connect the Wi-Fi interface as a client to the Wi-Fi network (in our case it is the mobile hotspot from your mobile) - Wireless -> WiFi interfaces -> wlan1 -> Scan -> find the WiFi network and press Connect. ( Once I see the SSID I want to connect to I have to click STOP, then click CONNECT )
When I click on “Connect” There is a red message “not running”
Clicking Connect causes the winbox gui to blink but has no other effect I can see.
Please excuse my inexperience, I’m assuming this means the interface wlan1 is not running.
An examination of > Interfaces
Shows
