I’m using Dude 4.0beta2, i have also search this function in previous versions. Could anyone tell me where can i change this default port OR if i can create tool (which variable) should I insert in “New tool” window..
http://forum.mikrotik.com/t/define-alternative-winbox-port/39207/5
Should be able to change port in a future version…
Thank You.
Has this been implemented yet? I can’t seem to find if it has or not.
