simple queue only limits upload
In the past, I just had to check “use IP Firewall”, then add a simple queue with target=ip address of local computer and max limit, burst limit, and burst time set to desired values for both “target upload” and “target download” columns.
With a couple of new mikrotiks, however, it is only limiting the upload according to the max/burst limits and giving full bandwidth to download.
Are there any other random settings besides “use IP firewall” which might be affecting simple queues? I have everything else (besides wifi password) set at default values
found the answer: you have to go into the “ip->firewall->filter rules” page and disable or delete “defcon fastrack”
nice!
Sent from my STV100-3 using Tapatalk
