Simple Queue Parenting Graphical Representation
I’m kinda new in MikroTik and I’m having issues with graphical representation of parents and childs in simple queue list. I would like to see it like this: https://imgur.com/uWgzTnw.
But I’m seeing this: https://imgur.com/DTkiOY9.
Is there any way I can see it as shown on the first picture?
Thank you for any help!
Just select parent option on the simple queue, it is on the second tab of simple queue configuration.
I’ve done that as you can see in 8. column. The problem is I’m seeing child like exactly under parent. I’d like to have it shifted.
Click on the Name column header. The list has to be sorted on any other than the # (number) column.
It works now. Thank you so much!
