Hi, i need a help to simple queue rule work between two interfaces, in this case i want to keep both on same range with different pools and half the connection to each ether;
Follow the resume from actualy config
Ether1 (PPPoE), Ether2 (192.168.2.5/24) and Ether3 (192.168.2.6/24)
I tried to bridge ether2 and 3, simple queue with target on ethers not work, after remove bridge and keep target on ethers worked, but ether3 cant access the internet, there’s a way to queue works between ether 2 and 3? below follow the router config:
# 2024-11-24 18:43:38 by RouterOS 7.16.1
# software id = V002-QEAN
# model = RB750r2
# serial number = 67D2066403C4
add name=bridge1
set [ find default-name=ether1 ]
set [ find default-name=ether2 ]
set [ find default-name=ether3 ]
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 user=\
xxxxxxx
/interface lte apn
add name=pool1 ranges=192.168.2.10-192.168.2.150
add name=pool2 ranges=192.168.2.151-192.168.2.254
add address-pool=pool1 interface=ether2 name=server1
add address-pool=pool2 interface=ether3 name=server2
/queue simple
add max-limit=2M/4M name=queue1 target=ether3
add max-limit=2M/4M name=queue2 target=ether2
set udp-timeout=10s
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.2.5/24 interface=ether2 network=192.168.2.0
add address=192.168.2.6/24 interface=ether3 network=192.168.2.0
add address=192.168.2.0/24 gateway=192.168.2.5,192.168.2.6
set servers=1.1.1.1,1.0.0.1
add action=masquerade chain=srcnat out-interface=pppoe-out1
add action=masquerade chain=srcnat dst-address=192.168.2.0/24 src-address=\
192.168.2.0/24
/ip hotspot profile
/ip ipsec profile
/ip service
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/routing bfd configuration
add disabled=no interfaces=all min-rx=200ms min-tx=200ms multiplier=5
/system clock
set time-zone-name=America/Sao_Paulo
/system identity
set name=xxx
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=xxx.xxx.xxx.xxx
