Simple recursive failover for bears of little brain
Recursive routing and failover setup making use of it is one among the many commonly needed features of a router that is - BTW like most useful things possible in RouterOS - either mis-documented or documented in such a complex and convolute way that bears of little brain like myself simply cannot grasp in their entirety.
By applying a (rest assured moderate) amount of torture to knowledgeable member CGGXANNX (whom I want to thank for the patience and the will to discuss and explain the matter) I managed to squeeze out of him the essential informations needed to create a simple recursive route that is also formally correct.
Only for the record there is an even simpler mnemonic method that - while working in most cases - is not correct, as it relies on RouterOS automagicallly correcting scope values of routes, a link to it is given here ONLY for reference, you should instead use the one described in the attached spreadsheet, anyway, for reference only, start from here:
Primary gateway with static ip address not activating - #17 by jaclaz
The approach used in the attached spreadsheet is a simple, practical, method that can be used and replicated without needing to understand fully the complexities of the way the values of scope and target-scope in routes play a crucial role in recursive routing.
People willing to better understand the matter can use (and peruse) the thread where this originated, with particular attention to posts by CGGXANNX, starting from here:
Anyway, here is a screenshot of last version (0.4):
and attached here is the original spreadsheet (also 0.4) in a .zip archive:
recursive.zip (8.5 KB)
As always, comments, corrections, (possibly constructive) critics are welcome.
EDIT:
Replaced files with latest version, 0.3 2025-12-19
Replaced files with latest version, 0.4 2025-12-20
Beginner's question about config dual wan failover + warp
Problems with PCC load balancing
How to handle two different ISPs, one with IPv6 and one with IPv4 for failover or/and load balance
Mirktoik E62iUGS-2axD5axT how to use without saturating CPU
Is the MikroTik l009 good enough?
Inactive route when gateway not in same subnet, but has ARP
VRF WAN 1 to LTE Failover Not Working
5G WAN failover gateway check
Wrong nat port
Dual WAN Failover /32 Issue
Dual ISP Failover setup is load balancing instead
Help me pls solve an USI route
Need help with Backup WAN fail over for only limited devices
RB5009 / RouterOS 7.25: Failover when an Xray/sing-box container tunnel loses its remote server
Wireguard Client - Traffic Routing Issue
DoubleWAN Problems (maybe bc iam thinking to cheap) Starlink and 5GTether over EtherTether
New to Mikrotik and seeking advice
Mangle does not forward to correct interface eventhough connexion mark areOK
Starlink with failover to LTE - best practice?
Failover question (using route+netwatch)
Recursive routing not failing over - possible icmp issue
Help with setting up IPv6 with MultiWAN on L009UiGS
