Hi all,
I can't seem to get the transparent proxy feature working on our MT.
I've followed the documentation with no luck.
Basically we have a box with 2 nics.
Works perfectly as a gateway, internal address range gets nat'd out the external interface.
No special rules atm.
I've setup the web proxy, works perfectly when the client puts the proxy address in their browser, eg, 192.168.0.1 8080
We want to take it one step further now and make it transparent, so the users don't need to make any changes on their browser.
I followed the documentaion here:
http://www.mikrotik.com/docs/ros/2.8/ip/webproxy.content
Transparent section, but it does not work.
I've tried ticking the box in winbox "transparent proxy", still no joy.
I'm sure it's something simple, any ideas ?
Some more info:
[admin@MikroTik] > /ip web-proxy export
feb/24/2005 07:44:33 by RouterOS 2.8.24
software id =
/ ip web-proxy
set enabled=yes src-address=0.0.0.0 port=8080 hostname="proxy"
transparent-proxy=no parent-proxy=0.0.0.0:0
cache-administrator="webmaster" max-object-size="200000 kB"
cache-drive=system max-cache-size=10000
/ ip web-proxy access
add dst-port=!443,563 method=connect action=deny comment="allow CONNECT only
to SSL ports 443 [https] and 563 [snews]" disabled=no
/ ip web-proxy cache
add url="cgi-bin \?" action=deny comment="don't cache dynamic http pages"
disabled=no
[admin@MikroTik] > /ip web-proxy monitor
status: running
uptime: 18h8m3s
clients: 2
requests: 1595
hits: 74
cache-size: 16428 kB
received-from-servers: 122496 kB
sent-to-clients: 152223 kB
hits-sent-to-clients: 29637 kB
Thanks for your time.
