I would like to know if it is possible to have my Mikrotik RB2011 act as both a VPN Client and VPN Server simultaneously?
I had it working fine as a PPTP VPN client. I then configured it to also be a PPTP VPN Server, which worked, but unfortunately disconnected the Client. The only way I could turn the Client back on was to disconnect the Server.
I deleted the PPTP Server and created an L2TP Server thinking that it would not conflict with the PPTP Client, but unfortuantely, it was the same exact situation.
Is there something I am not configuring properly or does this setup not work?
I am using Winbox if someone has any thoughts.
Thank you.
