Are there any plans to integrate a Sip-Proxy-Deamon like http://siproxd.sourceforge.net in MOS? This would be very usefull for many people doing NAT/Masquerading.
canram
canram
Ser Proxy works fine behind NAT with MT 2.9 give it a try.
Regards
Charles
Yes, you´re right. Many Proxies are running fine behind RouterOS. But what I´m looking for is a router with integrated proxy. If a customer wants to use two or three ip-phones behind an masquerading router, he don´t want to run a second machine only for sip-proxy.
I agree. it would be really an addition to the VOIP support. SIP is definatly the best VOIP so far and should be included for sure.
Mt only support h.323 (gatekeeper)
the mt is a router, is not too much add sip proxy?
MT in my opinion is not only a router. Look at the feature list ![]()
web-proxy, firewall, tunnels, vpn-server, …
A sip-proxy is only a litte missing feature and I´m sure Mikrotik will add a sip-proxy anytime.
Sip proxy will not be added in the RouterOS. But there will be a sip connection tracking so it could work with NAT and Masquerade. This feature will be ready approx. after 2 months.
Very Good. Thats an equivalent or even better solution, because the customer does not need to configure an outgoing proxy.
