Hello everyone, as described in the title I have an inter vlan speed problem, my network diagram is:
The interface eth1 and eth2 form a bridge for the LAN, there I created the VLAN 10, in the switchs I created the access ports and the trunk ports. All Hardware is gigabit ethernet. My router is:
routerOS: 6.37.5
routerboard: yes
model: CCR1036-12G-4S
factory-firmware: 3.33
current-firmware: 3.33
upgrade-firmware: 3.33
Configuration:
# jan/17/2018 10:43:19 by RouterOS 6.37.5
# software id = CQL1-KYMM
add name=bridge1
set [ find default-name=ether2 ] comment="ETH 2" mac-address=\
E4:8D:8C:08:7F:15 name=LAN
set [ find default-name=ether3 ] comment="ETH 3" mac-address=\
E4:8D:8C:08:7F:16 name=LAN1
set [ find default-name=ether1 ] auto-negotiation=no mac-address=\
E4:8D:8C:08:7F:14 name=WAN
set [ find default-name=ether4 ] mac-address=E4:8D:8C:08:7F:17
set [ find default-name=ether5 ] mac-address=E4:8D:8C:08:7F:18
set [ find default-name=ether6 ] mac-address=E4:8D:8C:08:7F:19
set [ find default-name=ether7 ] mac-address=E4:8D:8C:08:7F:1A
set [ find default-name=ether8 ] mac-address=E4:8D:8C:08:7F:1B
set [ find default-name=ether9 ] mac-address=E4:8D:8C:08:7F:1C
set [ find default-name=ether10 ] mac-address=E4:8D:8C:08:7F:1D
set [ find default-name=ether11 ] mac-address=E4:8D:8C:08:7F:1E
set [ find default-name=ether12 ] mac-address=E4:8D:8C:08:7F:1F
set [ find default-name=sfp1 ] mac-address=E4:8D:8C:08:7F:10
set [ find default-name=sfp2 ] mac-address=E4:8D:8C:08:7F:11
set [ find default-name=sfp3 ] mac-address=E4:8D:8C:08:7F:12
set [ find default-name=sfp4 ] mac-address=E4:8D:8C:08:7F:13
/interface gre
add !keepalive local-address=X.Y.Z.A name=Tunnel0 remote-address=\
X.Y.Z.A
/ip neighbor discovery
set LAN comment="ETH 2"
set LAN1 comment="ETH 3"
/interface vlan
add interface=bridge1 name=vlan10 vlan-id=10
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128-cbc,3des pfs-group=none
add name=clientes ranges=10.10.10.2-10.10.10.10
add name=dhcp_pool2 ranges=192.168.21.190-192.168.21.210
add name=dhcp_pool3 ranges=192.168.1.200-192.168.1.220
add address-pool=dhcp_pool3 disabled=no interface=vlan10 name=dhcp2
add name=dhcp_pool1 next-pool=dhcp_pool2 ranges=192.168.21.135-192.168.21.145
add address-pool=dhcp_pool1 disabled=no interface=bridge1 name=dhcp1
/ppp profile
add change-tcp-mss=yes dns-server=8.8.8.8 local-address=10.10.10.1 name=\
L2TP_VPN_PROFILE remote-address=clientes
/queue type
add kind=pcq name=NTTsw_Descargar pcq-classifier=src-address \
pcq-dst-address6-mask=64 pcq-limit=19000000KiB pcq-rate=19M \
pcq-src-address6-mask=64 pcq-total-limit=19000KiB
add kind=pcq name=NTTsw_Subir pcq-classifier=dst-address \
/queue tree
add max-limit=19M name=nttsw_descargar_total packet-mark=\
nttsw_descargar_total parent=bridge1 queue=NTTsw_Descargar
add max-limit=19M name=nttsw_subir_total packet-mark=nttsw_subir_total \
parent=WAN queue=NTTsw_Subir
/system logging action
add bsd-syslog=yes name=logUdpRemote remote=192.168.21.146 syslog-facility=\
local1 target=remote
add bsd-syslog=yes name=logTcpRemote remote=192.168.21.146 syslog-facility=\
local0 target=remote
add bridge=bridge1 interface=LAN
add bridge=bridge1 interface=LAN1
/interface l2tp-server server
set default-profile=L2TP_VPN_PROFILE enabled=yes ipsec-secret=\
############ max-mru=1460 max-mtu=1460 mrru=1600 use-ipsec=\
yes
/interface pptp-server server
set authentication=pap,chap,mschap1,mschap2
/ip accounting
set enabled=yes threshold=2560
/ip accounting web-access
set accessible-via-web=yes address=192.168.21.54/32
add address=X.Y.Z.A interface=WAN network=X.Y.Z.A
add address=192.168.21.1/24 interface=LAN network=192.168.21.0
add address=172.16.1.2/30 interface=Tunnel0 network=172.16.1.0
add address=192.168.1.1/24 interface=vlan10 network=192.168.1.0
/ip dhcp-server lease
add address=192.168.21.138 client-id=1:14:2:ec:3a:62:ac mac-address=\
14:02:EC:3A:62:AC server=dhcp1
add address=192.168.21.139 client-id=1:14:2:ec:3a:62:82 mac-address=\
14:02:EC:3A:62:82 server=dhcp1
add address=192.168.1.0/24 dns-server=8.8.8.8 gateway=192.168.1.1
add address=192.168.21.0/24 dns-server=192.168.21.50 gateway=192.168.21.1
Here some tests that I have done with iperf:
Virtual Machine in proxmox ------> Virtual Machine in Oracle : Bandwidth: 0,95 MBytes/s
Proxmox physical server ------> Oracle physical server : Bandwidth: 1,17 MBytes/s
Proxmox physical server ------> Other proxmox physical server: Bandwidth: 102 MBytes/s
Virtual Machine in proxmox ------> Interface VLAN Mikrotik: Bandwidth 40 MBytes/s
Virtual Machine in proxmox ------> Interface Bridge Mikrotik: Bandwidth: 48 MBytes/s
Oracle physical server -------> Other Oracle physical server: Bandwidth: 111 MBytes/s
Virtual Machine in Oracle -------> Interface Bridge Mikrotik: Bandwidth: 45 MBytes/s
Virtual Machine in oracle ------> Interface VLAN Mikrotik: Bandwidth: 24 MBytes/s
If you need more data, ask for it. I appreciate any help or hint, thanks.
