I live somewhere with terribly slow broadband, so I’ve got a second ISP connection and a Mikrotik router to balance it.
When I set up PCC, the second ISP only downloads at around 50 Kbit. But when I manually drop the first ISP’s connection, the download on the second ISP boosts to full speed.
To make things simpler, I’ve also tried using an address list instead of PCC. This segregates the second connection for downloads from certain servers, but it turns out that this still limits me to these low speeds, until ISP1 is disabled. Presumably at this point it is falling through to the default route?
Can anyone spot what I’ve done wrong?
Many thanks
TB
/ip dns static
add address=192.168.1.1 name=router
/ip firewall address-list
add address=1.2.3.4 list=ISP2_IP_AddressList
add address=2.3.4.5 list=ISP2_IP_AddressList
add action=accept chain=forward comment="defconf: accept established,related" connection-state=established,related
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface=ether1-WAN1
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=all-ppp
/ip firewall mangle
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=pppoe-out1 new-connection-mark=ISP1_conn passthrough=yes
add action=mark-connection chain=prerouting connection-mark=no-mark in-interface=pppoe-out2 new-connection-mark=ISP2_conn passthrough=yes
add action=mark-connection chain=prerouting comment="mark download traffic for isp2" connection-mark=no-mark dst-address-list=ISP2_IP_AddressList dst-address-type=!local in-interface=bridge1 new-connection-mark=ISP2_conn passthrough=yes
add action=mark-routing chain=prerouting connection-mark=ISP1_conn in-interface=bridge1 new-routing-mark=to_ISP1 passthrough=yes
add action=mark-routing chain=prerouting connection-mark=ISP2_conn in-interface=bridge1 new-routing-mark=to_ISP2 passthrough=yes
add action=mark-routing chain=output connection-mark=ISP1_conn new-routing-mark=to_ISP1 passthrough=yes
add action=mark-routing chain=output connection-mark=ISP2_conn new-routing-mark=to_ISP2 passthrough=yes
add action=masquerade chain=srcnat comment="defconf: masquerade" out-interface=pppoe-out1
add action=masquerade chain=srcnat out-interface=pppoe-out2
add check-gateway=ping distance=1 gateway=pppoe-out1 routing-mark=to_ISP1
add check-gateway=ping distance=1 gateway=pppoe-out2 routing-mark=to_ISP2
add check-gateway=ping distance=2 gateway=pppoe-out1
add check-gateway=ping distance=2 gateway=pppoe-out2
