Hello, I am pulling my hair out and I am not sure what to do. I have tried so many things so now I am turning to you all.
simple set up here.
100mb fiber → computer I can get 80 to 100 on a speed test.
100mb fiber → RB 1100ah → computer I can get 10 to 12 mb on a speed test
I have tried with completely blank router save for the simple masquerading.
This router has very few nat rules, it has two pppoe gateways and it routes to my wireless network with OSPF.
The issues is no matter what I do, I can not move very much data. I can do a btest though it another router and get ok results but when using any real data it moves like a snail.
I am still learning Mikrotik, but getting better. Any ideas, I am really stumped. I will post anything needed.
Yes, I went though and checked all the negotiation status I get 1Gbps with the Full duplex checked for anything that is gig and 100Mbps Full duplex for anything thats fast ethernet (radios)
Have you got OSPF running in nbma mode - it should be over a wireless link due to multicast issues over wifi. Also, is the wireless link a true WDS bridge? Again it should be.
Also, how many packets are you handling with this router? Are any getting dropped? What is the CPU usage while it is passing data? Can you provide a diagram of your setup so I can help more?
Any new info on this? I’m seeing the same behavior. 100Mb fiber connection, BW test between routers maxes it out, but btest on a PC only gets 7-10mb. I’ve been pulling my hair out on this for a while.
I feel like I am having the same issue. Any news for this?
I can do a bandwidth test from my customer’s routers that are PPPOE to me through my wireless network. For example one is queued to 6Mbps down and from the router’s bandwidth test to a Mikrotik router on a 100Mbps circuit gets a solid 6.1Mbps, never wavers. When I do the same btest from a PC on the network behind the Masquerade I get anywhere from .5Mbps to 6Mbps. It is all over the place and usually closers to the .5Mbps and 1Mbps bandwidth. If I open 5-6 tests on that PC it hits the 6Mbps out the internet and around .5Mbps to 1Mbps per test running. Is it the masquerade? This has baffled me for days and is really frustrating to my customers who’s internet is very sporadic on downloads and browsing.
Thanks for any advice or help. PPPOE MTU 1480 and MRU 1480 and the same on the Mikrotik 2011US at the customer site. My other customers are getting the same issue’s on Mikrotik RB751’s using PPPOE to my Mikrotik 1100AH.
