Hello all.
Im facing a very weird problem.
Im having a 5G internet connection with average 350mbps down / 120up.
My router is a RB3011.
Thing is wheneven i try to speedtest through wired on my computers, i get capped upload on around 3-5Mbps, while speedtesting on my phone through an AP connected to the same router i get full upload speeds.
Ive been reading about disabling Large send Offload on computers NIC but no good.
I resetted winsock still nothing.
Does anyone have any idea why is this happening?
Is this windows issue?NIC? or it needs special mangle rule to change mss from windows computer hosts?
Im confused
bump! anyone?
Perhaps you can share your config? And make sure to remove any personal information (/export hide-sensitive file=anynameyoulike).
add name=Local_Bridge
add name=PUB_Bridge
add name=hs-pool-12 ranges=192.168.100.101-192.168.100.254
add name=hs-pool-13 ranges=192.168.1.151-192.168.1.254
add address-pool=hs-pool-12 interface=PUB_Bridge lease-time=1h name=dhcp1
add address-pool=hs-pool-13 interface=Local_Bridge lease-time=1h name=dhcp2
/port
set 0 name=serial0
add bridge=PUB_Bridge interface=ether3
add bridge=PUB_Bridge interface=ether4
add bridge=Local_Bridge interface=ether10
add bridge=Local_Bridge interface=ether9
add bridge=Local_Bridge interface=ether8
add bridge=Local_Bridge interface=ether7
add bridge=Local_Bridge interface=ether5
add address=192.168.100.1/24 comment="hotspot network" interface=PUB_Bridge \
network=192.168.100.0
add address=192.168.1.1/24 comment="hotspot network" interface=Local_Bridge \
network=192.168.1.0
add address=192.168.5.3/24 interface=ether2 network=192.168.5.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m
/ip dhcp-client
add interface=ether6 use-peer-dns=no use-peer-ntp=no
add address=192.168.1.0/24 comment="hotspot network" gateway=192.168.1.1
add address=192.168.100.0/24 comment="hotspot network" gateway=192.168.100.1
set allow-remote-requests=yes servers=1.1.1.1,8.8.4.4
add action=drop chain=input dst-port=53 in-interface=Internet protocol=udp
add action=drop chain=input dst-port=53 in-interface=Internet protocol=tcp
add action=drop chain=forward dst-port=53 out-interface=!Internet protocol=\
udp
tcp
/ip firewall mangle
add action=change-mss chain=forward log-prefix=change-mss new-mss=\
clamp-to-pmtu out-interface=ether6 passthrough=yes protocol=tcp \
tcp-flags=syn
add action=change-ttl chain=postrouting new-ttl=set:64 out-interface=ether6 \
passthrough=no protocol=!icmp
add action=mark-routing chain=prerouting disabled=yes new-routing-mark=villa \
passthrough=no port=80,443,8080 protocol=tcp src-address=192.168.100.0/24
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
src-address=192.168.0.0/16
add action=dst-nat chain=dstnat dst-address=192.168.0.0/16 dst-port=44444 \
protocol=udp to-addresses=10.98.0.1 to-ports=40004
add action=redirect chain=dstnat dst-port=53 in-interface=!Internet protocol=\
udp
tcp
/ip firewall service-port
set sip ports=5060,5061,40004,40065
/ip hotspot user
add name=admin
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=192.168.5.100 \
pref-src=0.0.0.0 routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
add disabled=no distance=1 dst-address=208.67.222.222/32 gateway=192.168.11.1 \
pref-src=0.0.0.0 routing-table=main scope=11 suppress-hw-offload=no \
target-scope=10
/system clock
set time-zone-name=Europe/Athens
so it appears is a known windows bug?!?!
you have cutted too much from the config export
Well i haven’t actually.
This is it after a clean reset config and updated as well to latest rOS 7.3 ( to see if any better)
So… It was windows MTU issue.
Setting
netsh interface ipv4 set subinterface “Ethernet“ mtu=1380 store=persistent
did the job.
