Slow Upload Speeds (CCR2004-1G-12S+2XS)
Man, this is just bewildering. I have gigabit up/down. Laptop direct to the ONT (FIOS), I get about that. Every wired device on the network, the router itself included (btest/speedtest), gets significantly throttled upload speeds, somewhere between 4mbps and 40mbps, when it should be 800+mbps.
I’ve tried:
  • Flow Control
  • Pinning the interface speed to the 10G SR LR for the sfp on the uplink wan port
  • Fast Track Rules
… all zero effect.
Oddly, also, this doesn’t seem to affect wireless clients. Only wired ones. WTF?
add name=bridge1 port-cost-mode=short
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no rx-flow-control=on \
    speed=10G-baseSR-LR tx-flow-control=on
add name=WAN
add name=LAN
/interface wifi channel
add band=5ghz-ax disabled=no name="Hector Channels"
add band=2ghz-ax disabled=no name="Florry Channels" width=20mhz
/interface wifi datapath
add bridge=bridge1 disabled=no name="FDCP Datapath"
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disable-pmkid=yes disabled=no ft=\
    yes ft-over-ds=yes group-encryption=ccmp group-key-update=1h name=\
    "FDCP Security" wps=disable
/interface wifi steering
add disabled=no name="Hector Steering" neighbor-group=dynamic-Hector-5518dcee \
    rrm=yes wnm=yes
add disabled=no name="Florry Steering" neighbor-group=dynamic-Florry-5518dcee \
    rrm=yes wnm=yes
/interface wifi configuration
add channel="Hector Channels" country="United States" datapath=\
    "FDCP Datapath" disabled=no name="Hector 5GHz" security="FDCP Security" \
    security.ft=yes .ft-over-ds=yes ssid=Hector steering="Hector Steering" \
    tx-power=15
add channel="Florry Channels" datapath="FDCP Datapath" disabled=no name=\
    "Florry 2GHz" security="FDCP Security" security.ft=yes .ft-over-ds=yes \
    ssid=Florry steering="Florry Steering" tx-power=15
add name=dhcp_pool0 ranges=10.62.14.128-10.62.14.190
add address-pool=dhcp_pool0 interface=bridge1 lease-time=1w1d name=dhcp1
/ip smb users
/port
set 0 name=serial0
/system logging action
add email-to=noc@nnix.com name=email target=email
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" \
    disabled=yes disabled=yes name=zt1 port=9993
add bridge=bridge1 comment="csw1 uplink" interface=sfp-sfpplus12 \
    internal-path-cost=10 path-cost=10
add bridge=bridge1 comment="gets all the wifi interfaces" interface=dynamic
set udp-timeout=10s
set discover-interface-list=all lldp-med-net-policy-vlan=1
/ipv6 settings
set disable-ipv6=yes
/interface detect-internet
set detect-interface-list=all
add interface=sfp-sfpplus1 list=WAN
/interface wifi capsman
set ca-certificate=auto enabled=yes interfaces=bridge1 package-path="" \
    require-peer-certificate=no upgrade-policy=require-same-version
/interface wifi provisioning
add action=create-dynamic-enabled disabled=no master-configuration=\
    "Hector 5GHz" radio-mac=48:A9:8A:CA:18:22
    "Hector 5GHz" radio-mac=D4:01:C3:67:EA:76
    "Florry 2GHz" radio-mac=48:A9:8A:CA:18:23
    "Florry 2GHz" radio-mac=48:A9:8A:C7:94:81
    "Florry 2GHz" radio-mac=D4:01:C3:67:EA:77
    "Hector 5GHz" radio-mac=48:A9:8A:C7:94:80
    "Florry 2GHz" radio-mac=F4:1E:57:04:B5:4C
    "Hector 5GHz" radio-mac=F4:1E:57:04:B5:4D
add address=10.62.14.1/24 comment="fernditch.com LAN range" interface=bridge1 \
    network=10.62.14.0
/ip arp
add address=10.62.14.42 interface=bridge1 mac-address=98:06:3C:24:AB:C9
/ip cloud
set ddns-enabled=yes ddns-update-interval=20m
/ip dhcp-client
add interface=sfp-sfpplus1 use-peer-dns=no use-peer-ntp=no
add address=10.62.14.0/24 dns-server=94.140.14.49,94.140.14.59 domain=\
    fernditch.com gateway=10.62.14.1 ntp-server=10.62.14.1
set cache-size=4096KiB servers=94.140.14.49,94.140.14.59
add action=accept chain=forward connection-state=established,related
/ip ipsec profile
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=10.0.0.0/8 disabled=yes
set ssh address=10.0.0.0/8
set api address=10.0.0.0/8 disabled=yes
set winbox address=10.0.0.0/8
set api-ssl address=10.0.0.0/8 disabled=yes
/ip smb shares
set [ find default=yes ] directory=/pub
/system clock
set time-zone-autodetect=no time-zone-name=America/New_York
/system identity
set name=rtr1
/system logging
add action=email topics=critical,warning,account
add topics=wireless
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address=0.pool.ntp.org
add address=1.pool.ntp.org
add address=2.pool.ntp.org
/system routerboard settings
set enter-setup-on=delete-key
What is the static arp entrie for?
Disable detect-internet.
Disable flow controll.
Keep the fasttrack rules.
Did you try a different port? Try the ethernet1/mgmt/boot port without adding it to the bridge or any of the other ports.
Disable capsman and try again? Or remove the capsman from the bridge to test. Might be causing issues for some weird reason?
Other then that looks fine to me.
Static arp
  • static arp is a legacy thing from an old config, good catch! I removed it, no effect. Left off.
Detect-internet
  • disabled (set to none), no effect. Left off.
Flow Control
  • disabled (set to off), no effect. Left off.
Capsman
  • disbled, no effect. Re-enabled.
I’ll try the management port in a bit, that’s a good idea too, thanks.
Current (updated) config after suggested changes above:
set [ find default-name=sfp-sfpplus1 ] auto-negotiation=no speed=\
    10G-baseSR-LR
add name=WAN
add name=LAN
    rrm=yes wnm=yes
    rrm=yes wnm=yes
    tx-power=15
/ip smb users
/port
set 0 name=serial0
/zerotier
set udp-timeout=10s
/ipv6 settings
    network=10.62.14.0
/ip cloud
/ip dhcp-client
/ip ipsec profile
/ip service
/ip smb shares
/system clock
/system identity
set name=rtr1
/system logging
add topics=wireless
/system note
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
Ok, I tested on the switch eth (built in) port using a laptop, and it was the same - fast download, relatively slow upload. Very strange! I’m kinda out of ideas here.
Fixed!!
Well, at least, speed fixed. Mystery remains in some ways.
I swapped the uplink SFP, a 10gtek part, with another SFP, also a 10gtek part of the same number but different revision. No idea why this fixes the upload, they negotiate to the same speed, have the same status lights, etc.
But now I’m wondering: if it was the SFP, as it appears to have been, why on earth would wireless clients not be affected??? They’re just caps on the same switch as everything wired, subject to the same uplink SFP which may have been faulty. WTF?
