Sluggish Internet and No internet on ports 2-10
First of all, I am a newbie with the RouterOS and maybe my questions are stupid but I was not able to find a solution in Google and here in the forum.
Recently, I have bought Mikrotik RB2011 Uias-2hnd-in and now I am facing 2 issues:
  1. I have configured the router on port Ethernet1(POE) and the internet speed is sluggish. I am using the default settings/configuration of the Quick Setup.
    When I am using the LAN cable directly into my laptop the speed is 70MB download and 40mb upload, but using the WiFi signal it is not more than 10MB download and 3MB upload.
I tried using different configuration suggested in this forum and Google but the speed is the same.
  1. In order to try better speed, I have setup the LAN cable into ETH2 and ETH8 but there is no internet signal. The router is able to get IP information from my ISP but the WiFi signal does not have an internet connection.
    I am totally sure that I am doing something wrong, but I do not know how to find what exactly.
Could you please, tell me how I can debug the both issues and if you can provide me with some information it will be great. I am not sure what else information I can provide you.
Thank you for your time!
