small Bandwidth
Hi all we have 2 location with distance 30 km using RB 532 with using card R52 and get signal strength -73 and other side -76 but the connection using ap birdge and station wds. without using compression and nstreme runnning at 2374
when do the bandwidth test with tcp option and using both we get only 23.1 kbps/350.8 kbps on Tx/Rx Average.
any setting must be set …?
What are your speeds modulation and ccq?
Also, if you’re running v3, double click on the connection in the wireless registrations tab and go to the signal tab. What is the P throughput?
try link w/o wds. simply bridge and station.
after all clear and bandwidth tests good - add wds, bridges and so on.
several years before we help friend in a same situation with this plan
Possible cause:
  1. Speed rates to high, lower it.
  2. Try to disable the nstreme.
  3. Give the results of ping test.
