Dear all,
I have a problem with a smart plug that continuously disconnect (regularly) from the router (hAC lite); the Router OS is updated to the 6.45.8 (Long-term) and in the following you can find an extract of the Log File
feb/16/2020 9:21:11 by RouterOS 6.45.8
software id = 5IF1-FLNE
03:40:27 wireless,debug wlan1: 5C:41:5A:23:C4:54 attempts to associate
03:40:27 wireless,debug wlan1: 5C:41:5A:23:C4:54 not in local ACL, by default accept
03:40:27 wireless,info 5C:41:5A:23:C4:54@wlan1: connected, signal strength -57
03:40:28 dhcp,info dhcp1 deassigned 192.168.100.235 from 5C:41:5A:23:C4:54
03:40:28 dhcp,info dhcp1 assigned 192.168.100.235 to 5C:41:5A:23:C4:54
04:02:11 wireless,info 5C:41:5A:23:C4:54@wlan1: disconnected, received disassoc: sending station leaving (8)
04:02:29 wireless,debug wlan1: 5C:41:5A:23:C4:54 attempts to associate
04:02:29 wireless,debug wlan1: 5C:41:5A:23:C4:54 not in local ACL, by default accept
04:02:29 wireless,info 5C:41:5A:23:C4:54@wlan1: connected, signal strength -56
04:24:18 wireless,info 5C:41:5A:23:C4:54@wlan1: disconnected, received disassoc: sending station leaving (8)
04:24:36 wireless,debug wlan1: 5C:41:5A:23:C4:54 attempts to associate
04:24:36 wireless,debug wlan1: 5C:41:5A:23:C4:54 not in local ACL, by default accept
04:24:36 wireless,info 5C:41:5A:23:C4:54@wlan1: connected, signal strength -59
04:24:37 dhcp,info dhcp1 deassigned 192.168.100.235 from 5C:41:5A:23:C4:54
04:24:37 dhcp,info dhcp1 assigned 192.168.100.235 to 5C:41:5A:23:C4:54
04:46:20 wireless,info 5C:41:5A:23:C4:54@wlan1: disconnected, received disassoc: sending station leaving (8)
04:46:38 wireless,debug wlan1: 5C:41:5A:23:C4:54 attempts to associate
04:46:38 wireless,debug wlan1: 5C:41:5A:23:C4:54 not in local ACL, by default accept
04:46:38 wireless,info 5C:41:5A:23:C4:54@wlan1: connected, signal strength -56
04:46:38 dhcp,info dhcp1 deassigned 192.168.100.235 from 5C:41:5A:23:C4:54
While the Amazon Echo is correctly connected from one week, this plug is unusable. Note that before I was using another router and I never had problems with the plug.
In the meantime I tried the following think (unsuccessfully):
- change channel of the WiFi in the 2.4 band;
- change the timeout
- test another plug (to avoid a problem of the plug itself).
Attached you will find the complete log. Any input/suggestion would be really appreciated to try to solve this annoying issue.
Kind regards,
Giorgio
log_16022020.txt (67 KB)
