Hi Forum,
I would like to mount a smb share from my
Mikrotik 2011UiAS-2HnD Firmware 6.46.2
I’m aware about:
https://wiki.mikrotik.com/wiki/Manual:IP/SMB
Note: RouterOS only supports SMB v1.0 and v2.002
and got these on my OmniOS Client.:
# mount -F smbfs //user1@mikrotik/share /media/Keys
Password:
mount: //mikrotik: login failed: syserr = Operation not supported
(no more details in log file)
Let’s sniff and have a look at pcap …
OmniOS → Mikrotik
SMB (Server Message Block Protocol)
SMB Header
Negotiate Protocol Request (0x72)
Word Count (WCT): 0
Byte Count (BCC): 38
Requested Dialects
Dialect: NT LANMAN 1.0
Buffer Format: Dialect (2)
Name: NT LANMAN 1.0
Dialect: NT LM 0.12
Name: NT LM 0.12
Dialect: SMB 2.???
Mikrotik → OmniOS
SMB Header
Negotiate Protocol Response (0x72)
Word Count (WCT): 17
Selected Index: 1: NT LM 0.12
Security Mode: 0x03, Mode, Password
.... ...1 = Mode: USER security mode
.... ..1. = Password: ENCRYPTED password. Use challenge/response
.... .0.. = Signatures: Security signatures NOT enabled
.... 0... = Sig Req: Security signatures NOT required
Max Mpx Count: 50
Max VCs: 1
Max Buffer Size: 65532
Max Raw Buffer: 65536
Session Key: 0x2908f430
Capabilities: 0x00000258, Large Files, NT SMBs, NT Status Codes, NT Find
System Time: Feb 12, 2020 17:35:00.000000000 CET
Server Time Zone: 180 min from UTC
Challenge Length: 8
Byte Count (BCC): 8
Challenge: 30facc9bf8148e65
What, NT LM 0.12 was negotiated…?!?
Next packet is a TCP [ACK]
Flags: 0x010 (ACK)
000. .... .... = Reserved: Not set
...0 .... .... = Nonce: Not set
.... 0... .... = Congestion Window Reduced (CWR): Not set
.... .0.. .... = ECN-Echo: Not set
.... ..0. .... = Urgent: Not set
.... ...1 .... = Acknowledgment: Set
.... .... 0... = Push: Not set
.... .... .0.. = Reset: Not set
.... .... ..0. = Syn: Not set
.... .... ...0 = Fin: Not set
[TCP Flags: ·······A····]
and finally a TCP [RST, ACK]
Flags: 0x014 (RST, ACK)
.... .... .1.. = Reset: Set
[Expert Info (Warning/Sequence): Connection reset (RST)]
[TCP Flags: ·······A·R··]
Can provide whole pcap (8 packets) via PM.
Does anyone has any hints for me?
From my Arch Linux Client mounting works fine.
