SMS notification again... I'm stuck...
Actually i run The Dude under Windows cos it is the simplest way.
I have Oracle VBox with Debian 6 guest and installed sms server tools on it.
I am able to execute command in linux shell like sendsms (with will send specific message on specific number if i add parameters)
I’m also able to create file in Debian guest in specific direction witch specific content witch will send sms like command sendsms describe above.
I spend some time on google searching and I’m now able to create a file under Windows host in direction witch is shared with Linux guest (there was some permissions problems but finally i solved it). Like u probably know this file will execute sending of sms…
And the last, how to create a specific file in specific location and specific (I know to much specific) content using execute on server notification?
I was trying to use The Dude under Linux, OzekiSMSGateway, Kannel but they to not make it works…
I am fighting with this over week… Any solutions like Email to sms wont be the best cos they wont work when i lost may gateway.
If anyone have some advice i will be grateful.
Sorry for my English :slight_smile:
Cant understand the question… You can search for execute to find out how to make execute work.
http://forum.mikrotik.com/search.php?keywords=execute&terms=all&author=&fid[]=8&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
