SMTP Postfix Server Configuration
I’m trying to configure a Postfix server. I’m being able to receive emails, but I cannot send emails because it seems that the outgoing port connection 25 is somehow not being able to connect.
When i try to telnet the external server, I get this:
telnet gmail-smtp-in.l.google.com 25
Trying 142.250.0.27...
Trying 2800:3f0:4003:c03::1a...
telnet: Unable to connect to remote host: Network is unreachable
I’ve tried a lot of suggestions from other threads but none of them worked, I end up with the following configuration:
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input comment="allow openvpn udp port 1194" dst-port=1194 in-interface-list=!LAN protocol=udp
add action=drop chain=input comment="drop everything else not from LAN" in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=dst-nat chain=dstnat comment="forward mail ports to 10.10.20.105" dst-address=!10.10.20.0/24 dst-address-type=local dst-port=25,443,993 protocol=tcp to-addresses=10.10.20.105
add action=masquerade chain=srcnat comment="Harpin Nat"
Any suggestion will be very appreciated.
Carlos
If you have an appropriate computer (e.g. linux machine), try to run tcptraceroute towards TCP port 25 of smtp gateway of google. It should show the place where connection gets blocked. It wouldn’t surprise me if it would be your ISP blocking connections to plain SMTP port in attempt to block e-mail spam.
I did the traceroute, it seems that this is going after my ISP (invistanet). I’m not sure how to read the remaining stars (*), not sure if this is going thru or just rebouncing.
traceroute gmail-smtp-in.l.google.com -p 25
traceroute to gmail-smtp-in.l.google.com (142.250.0.27), 30 hops max, 60 byte packets
 1  _gateway (10.10.20.80)  9.415 ms  9.127 ms  9.148 ms
 2  143-202-28-198.customer.invistanet.com.br (143.202.28.198)  10.502 ms  10.067 ms  10.181 ms
 3  143-202-29-30.customer.invistanet.com.br (143.202.29.30)  21.198 ms  21.037 ms  20.877 ms
 4  143-202-28-38.customer.invistanet.com.br (143.202.28.38)  20.717 ms  20.555 ms  20.380 ms
 5  72.14.218.100 (72.14.218.100)  20.219 ms  20.525 ms  19.898 ms
 6  * * *
 7  * * *
 8  * * *
 9  * * *
10  * * *
11  * * *
12  * * *
13  * * *
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
20  * * *
21  * * *
22  * * *
23  * * *
24  * * *
25  * * *
26  * * *
27  * * *
28  * * *
29  * * *
30  * * *
You should allow TCP port 25 with an “accept” rule in /ip/filter BEFORE the “drop !LAN” rule.
tcptraceroute = not the same thing as traceroute
And allowing any port won’t help, because they are all allowed already. Look at forward, not input, there’s no drop in forward.
my ISP was blocking the incoming of ports below 1024. Sorry for the inconvenience!
