I have recently started using RouterOS on my x86 machine but i am now encountering weird issue. I am running RouterOS for PPTP VPN Server with Multiple Public IP’s.
Here is the the problem i am facing , I have setup PPTP Server , user: ppp1 has been assigned Local IP : 172.16.2.1 and Remote IP as : 172.16.2.15
and 172.16.2.15 SNAT to address xx.xx.xx.12 ( Public IP and also Primary IP ) - It works well i am able to surf the Internet and my Public ip is visible as xx.xx.xx.12
But here is the issue
When 172.16.2.15 SNAT to addresss xx.xx.xx.180 ( Additional IP under ether1 ) - Unable to surf , DNS look up fails , I can ping 8.8.8.8 , If i try to open a website through IP, Chrome says “Error 324 (net::ERR_EMPTY_RESPONSE): The server closed the connection without sending any data.”
This will happen to all IP from xx.xx.xx.180 to xx.xx.xx.189 , but if i try xx.xx.xx.191 it will work i will see xx.xx.xx.191 as public IP.
What do you think what am i doing wrong ?
Thank you
This will happen with
