Sniff file viewer
i have started a packet sniffer and file saved as a sniff. But how can i read this sniff file from Files Menu ???
thnxs,
raktim
I don’t know what you mean by ‘file menu’, but the sniffer files are in pcap format. You can use them with tcpdump or wireshark and many other tools that can read that format.
just drag’n’drop the file from the WinBox to any folder in Windows
of use ftp client to connect to RouterOS ftp server
Yes, drag the file to your desktop, and use Wireshark program to open it.
one more trick, if you get in the habit of naming that sniffer file with extension .pcap, you can just double click it after dragging to your desktop and it will automatically use wireshark.
