Since RouterOS 7.3
- snmp - report "ifSpeed" as 0 if value out of bounds (use "ifHighSpeed" for high speed interfaces instead);
but RFC https://www.rfc-editor.org/rfc/rfc1573.html says:
ifSpeed OBJECT-TYPE
SYNTAX Gauge32
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"An estimate of the interface's current bandwidth in
bits per second. For interfaces which do not vary in
bandwidth or for those where no accurate estimation
can be made, this object should contain the nominal
bandwidth. If the bandwidth of the interface is
greater than the maximum value reportable by this
object then this object should report its maximum
value (4,294,967,295) and ifHighSpeed must be used to
report the interace's speed. For a sub-layer which
has no concept of bandwidth, this object should be
zero."
::= { ifEntry 5 }
The question is - why MikroTik changed ifSpeed to 0? Can it be RFC compliant? 0 means no concept of bandwidth...
Pawel
