snmp probe compare the oid lookup value
hello
fast question is " is it possible to compare oid lookup value instead of its integer value in SNMP probe ? "
the full story below :
i am using the dude to monitor many devices of my network including the UPS , and am using telegram api for notifications to inform me of the probe status
i am monitoring the following OID 1.3.6.1.2.1.33.1.4.1.0 which is an integer
in the appearance lable i put
status:[oid("1.3.6.1.2.1.33.1.4.1.0")]
and the output is “status:normal (3)”
i defined an SNMP probe to compare the value of the above oid if it is equal 3 or not
when the service is not equal 3 it is considered as down and i get a telegram notification says
“Service UPS.status on rackUPS is now down (statement 5 == 3 not true)”
instead of this , i want to compare the lookup value instead of the integer value in the probe and see if it is equal “normal”
so when i get a notification it would say "Service UPS.status on rackUPS is now down (statement onbattery == normal not true)
and so back to the first question is it possible to compare oid lookup value instead of its integer value in SNMP probe ? if not do you agree to add this feature in the dude server ?
You’d be better off to write a function probe to get the solution you want rather than the auto-created probes that just do the value compare as in your example. Look in the Probes thread there are heaps of examples about how to do this.
