SNMP setup on Miktotik with zabbix
I am trying to setup SNMP so i can monitor my mikrotik networking devices with zabbix
I believe i did everything right but getting “No SNMP data collection” error
Can someone please tell me what i am missing?
Here is my setup on mikrotik
[admin@MikroTik] > snmp community print
Flags: * - DEFAULT; X - DISABLED
Columns: NAME, ADDRESSES, SECURITY, READ-ACCESS, WRITE-ACCESS
#    NAME             ADDRESSES  SECURITY  READ-ACCESS  WRITE-ACCESS
0 *X public           ::/0       none      yes          no
1    testandtest  ::/0       none      yes          no
[admin@MikroTik] > snmp print
          enabled: yes
          contact: ccr2004@mikrotik.local
        engine-id:
      src-address: ::
      trap-target:
   trap-community: testandtest
     trap-version: 1
  trap-generators: temp-exception
and here is setup on zabbix
Check your firewall settings.
Most likely udp/161 is not being allowed (it isn’t by default).
I see, yeah i didn’t realize i have to allow it
So i have to add a firewall rule to allow it?
or i have to open port somewhere?
mind helping with command to allow it?
or where in documentation they have this
@holvoetn got it to work now
thanks to you
i added firewall rule to accept all from the zabbix address to CCR address
and another one rule to accept all from the CCR address to zabbix address
and boom i can now see network graphs already
using SNMPv3!!!
I’m getting into Zabbix right now as well.
May some experienced folk could answer some of my questions :slight_smile:
  1. Do you know the purpose of
temp-exception
2. I tried to get SNMPv3 working without auth etc. is that possible at all?
3. When is it necessary to set
trap-target
4. luckelly there is a template for pretty much any MT device but the dashboard is very simple. Is there any community template you would recommend?
thank you
Stefan
