about license - when 2.9 was current licensing was time based, changing to 3.0 introduced change that allowed to update till some major version as it is now, demo (no license, 24 hour use) license still use that
point of my post is to show that using simple commands I can read named values from 450G and it is not really clear what problem you have. Can you try very same commands on your device? Can you check if you have configured SNMP on your device correctly.
edit:
values should be divided by 10 as values are reported as deka values 1V = 10dV
The problem is that they’re inaccessible via SNMP after a fresh boot. The OID parent needs to be walked before the actual temperature and voltage OIDs return data. Did the SNMP commands in my first post make sense?
Those work fine.
Yup, it is.
Please reread my original post and quote anything you don’t understand.
now when you say all the details it is perfectly clear where the problem is - health monitoring is kind of slow when router reboots and SNMP requests values in first couple of minutes you can get timeout. Good news - problem is know and acknowledged, bad news - it is not high on priority list.
Again, it’s not just a matter of waiting for the monitoring values to be populated after boot up. It is that they are sometimes not there. If it is an after power cycle, they don’t show up for days without being kicked by snmpwalk.
After downgrading a bunch of 450G/493G back to 4.17 due to various bugs in v5.5 - 5.12, I now have exactly the same problem.
A snmpwalk resolves it till the next reboot.
Not working temepratura and voltage, and the other RB if that works for me is a RB1100AHx2, and I have another that if it works, look at the mistake.
$snmpget -c public -v 1 192.168.23.1 .1.3.6.1.4.1.14988.1.1.3.8.0
Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: iso.3.6.1.4.1.14988.1.1.3.8.0
$snmpget -c public -v 1 192.168.23.1 .1.3.6.1.4.1.14988.1.1.3.10.0
Error in packet
Failed object: iso.3.6.1.4.1.14988.1.1.3.10.0
