Hi
RB2011 routerOS downgraded from 6.9 to 6.7
now when I try and add an NTP ip address into SYSTEM/ SNTP CLIENT I get the message ‘Couldn’t change SNTP Client - feature is not implemented (2)’
an internet search suggested the package is missing but I downloaded all_packages-mipsbe-6.7.zip uploaded the npk files to the router, ran the downgrade successfully and then did a factory reset to clear the config that was still present. I can see ntp-6.7-mipsbe.npk was in the original file list.
my SYSTEM / SERVICE LIST does not show ntp but
I can see ntp listed if I type system package print
