We are trying to set up a PPPoE/eBGP connection to our service provider (BT). The circuit is an IP Unnumbered IP Connect circuit if that helps. we have been provided all the necessary information however we can’t seem to get it to establish. We have been sent an example Cisco config to follow and have substituted our information in, could someone translate the config below into a Mikrotik config for a HEX Router?
*interface Loopback1
description ** IP Connect Primary WAN IP Address **
ip address 10.20.16.4 255.255.255.255
interface Ethernet0/1/0
description *** Primary Access IEUK656876 ***
no ip address
load-interval 30
ethernet oam mode passive
ethernet oam remote-loopback supported
ethernet oam
interface Ethernet0/1/0.101
description ** FDSL209673 **
encapsulation dot1Q 101
pppoe enable group global
pppoe-client dial-pool-number 1
interface Dialer1
description ** SFBB PPPoE Primary Logical Interface **
ip unnumbered Loopback1
encapsulation ppp
load-interval 30
dialer pool 1
ppp chap hostname USERNAME GOES HERE
ppp chap password PASSWORD GOES HERE
no cdp enable
router bgp 64512
no synchronization
bgp log-neighbor-changes
neighbor 81.144.23.167 remote-as 2856
neighbor 81.144.23.167 ebgp-multihop 3
neighbor 81.144.23.167 update-source Loopback1
neighbor 81.144.23.167 timers 10 30
ip route 0.0.0.0 0.0.0.0 81.144.23.167
If you give the supplier who sold you those two Hex 750Gr3’s a quick phone call, they’ll be more than happy to help you set this up and try to get it up and running for you asap!
I am still struggling with this. The below is an actual config I have put in place on a cisco router. This works perfectly. I am struggling I believe with the “ip unnumbered Loopback1” - Would setting a static /32 ip on the pppoe interface do the equivalent on the mikrotik? (I can answer that as a no), therefore Im really struggling how to achieve the same results. Currently I get the error; Could not determine remote IP (on the PPPOE status). Any advice would be greatly appreciated.
interface Loopback1
no ip address
load-interval 30
interface Dialer1
encapsulation ppp
load-interval 30
dialer pool 1
no cdp enable
router bgp 64512
no synchronization
