[Solved] ROS 6.36: NTP Client not working
I am trying to get my NTP Client running on two different Mikrotik devices but non of them work. Both have ROS 6.36, one device is a mAP, the other one a RB3011. The mAP uses Tool/SNTP Client with NTP Server “0.de.pool.ntp.org” which resolves in IP 148.251.68.100. After doing apply nothing is getting received but logs show instead:
19:53:09 echo: ntp,debug Wait for 0 seconds before sending next message
19:53:09 echo: ntp,debug,packet sending to 188.40.99.69 NTP packet (48 bytes)
19:53:09 echo: ntp,debug,packet VN=4
19:53:09 echo: ntp,debug,packet Mode=3 (Client)
19:53:09 echo: ntp,debug,packet TransmitTimestamp=db670c051702a348
19:53:09 echo: ntp,debug Wait for 16 seconds before sending next message
19:53:25 echo: ntp,debug Wait for 16 seconds before sending next message
19:53:41 echo: ntp,debug,packet sending to 148.251.68.100 NTP packet (48 bytes)
19:53:41 echo: ntp,debug,packet VN=4
19:53:41 echo: ntp,debug,packet Mode=3 (Client)
19:53:41 echo: ntp,debug,packet TransmitTimestamp=db670c251660a201
19:53:41 echo: ntp,debug Wait for 16 seconds before sending next message
Internet connection is working fine on this device. Connection works over a FritzBox 7490… Ping is working to NTP Server 148.251.68.100.
Any help would be appreciated…
Regards toby
@Mikrotik
I am reading of a lot of NTP issues in RouterOS. Are you still investigating this issue or do you see it as solved? Currently I don’t know how to debug this problem further. Should I send a Supout.rif?
I can only add that I use NTP on MikroTik in different versions and configurations (with and without the server)
and I have never seen such issues. They may be caused by external factors like firewall filters inside and
outside the router, settings of connection tracking, etc.
Problem is solve now. It seems that the FritzBox was blocking this traffic somehow. Now I use bridged modem connected to the RB3011 and it works…
