[SOLVED] VLANs, Virtual AP and HotSpot on bridged interface
Here's my scenario :
VLAN 1 = "LAN" network (192.168.10.0/24)
VLAN 2 = "FREE" network (192.168.11.0/24)
VLAN 3 = "POS" network (192.168.12.0/24)
The basic configuration (without Hotspot) works without problems - I can connect to both APs and "Port 2" with my notebook, get addresses from DHCP and can browse the Internet. I can also connect to other devices in different VLANs without problems.
Now I wanted to put a Hotspot on "AP FREE" Virtual AP and limit the clients so they can only use the Internet for 1 minute (this time frame is just for testing purposes).
I added the Hotspot to the bridged interface "Bridge FREE", but the Hotspot isn't working (no splash or any other page).
What am I doing wrong? Here's my configuration...
My VLAN configuration :
Flags: X - disabled, R - running, S - slave
NAME MTU ARP VLAN-ID INTERFACE
0 R VLAN "FREE" 1500 enabled 2 Port 1 - Trunk
1 R VLAN "LAN" 1500 enabled 1 Port 1 - Trunk
2 R VLAN "POS" 1500 enabled 3 Port 1 - TrunkMy INTERFACE configuration :
NAME TYPE MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 R Port 1 - Trunk ether 1500 1598 2028 D4:CA:6D:CA:22:68
1 S Port 2 ether 1500 1598 2028 D4:CA:6D:CA:22:69
2 Port 3 ether 1500 1598 2028 D4:CA:6D:CA:22:6A
3 Port 4 ether 1500 1598 2028 D4:CA:6D:CA:22:6B
4 Port 5 ether 1500 1598 2028 D4:CA:6D:CA:22:6C
5 S AP "FREE" wlan 1500 2290 D6:CA:6D:CA:22:6D
6 S AP "POS" wlan 1500 2290 D4:CA:6D:CA:22:6D
7 R Bridge "FREE" bridge 1500 1594 D4:CA:6D:CA:22:68
8 R Bridge "LAN" bridge 1500 1594 D4:CA:6D:CA:22:68
9 R Bridge "POS" bridge 1500 1594 D4:CA:6D:CA:22:68
10 RS VLAN "FREE" vlan 1500 1594 D4:CA:6D:CA:22:68
11 RS VLAN "LAN" vlan 1500 1594 D4:CA:6D:CA:22:68
12 RS VLAN "POS" vlan 1500 1594 D4:CA:6D:CA:22:68My BRIDGE configuration :
0 R name="Bridge "FREE"" mtu=1500 l2mtu=1594 arp=enabled mac-address=D4:CA:6D:CA:22:68 protocol-mode=rstp priority=0x8000 auto-mac=yes admin-mac=00:00:00:00:00:00
max-message-age=20s forward-delay=15s transmit-hold-count=6 ageing-time=5m
1 R name="Bridge "LAN"" mtu=1500 l2mtu=1594 arp=enabled mac-address=D4:CA:6D:CA:22:68 protocol-mode=rstp priority=0x8000 auto-mac=yes admin-mac=00:00:00:00:00:00
2 R name="Bridge "POS"" mtu=1500 l2mtu=1594 arp=enabled mac-address=D4:CA:6D:CA:22:68 protocol-mode=rstp priority=0x8000 auto-mac=yes admin-mac=00:00:00:00:00:00
My PORT configuration :
Flags: X - disabled, I - inactive, D - dynamic
INTERFACE BRIDGE PRIORITY PATH-COST HORIZON
0 VLAN "LAN" Bridge "LAN" 0x80 10 none
1 VLAN "FREE" Bridge "FREE" 0x80 10 none
2 VLAN "POS" Bridge "POS" 0x80 10 none
3 I Port 2 Bridge "LAN" 0x80 10 none
4 I AP "POS" Bridge "POS" 0x80 10 none
5 I AP "FREE" Bridge "FREE" 0x80 10 none
My IPADDRESS configuration :
ADDRESS NETWORK INTERFACE
0 192.168.10.2/24 192.168.10.0 Bridge "LAN"
1 192.168.12.2/24 192.168.12.0 Bridge "POS"
2 192.168.11.2/24 192.168.11.0 Bridge "FREE"My ROUTES configuration :
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme, B - blackhole, U - unreachable, P - prohibit
DST-ADDRESS PREF-SRC GATEWAY DISTANCE
0 A S 0.0.0.0/0 192.168.10.1 1
1 ADC 192.168.10.0/24 192.168.10.2 Bridge "LAN" 0
2 ADC 192.168.11.0/24 192.168.11.2 Bridge "FREE" 0
3 ADC 192.168.12.0/24 192.168.12.2 Bridge "POS" 0My DHCP configuration :
NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 dhcp "POS" Bridge "POS" Pool "POS" 1d
1 dhcp "FREE" Bridge "FREE" Pool "FREE" 35mMy DHCP NETWORK configuration :
0 ;;; AP "FREE" network
192.168.11.0/24 192.168.11.1 192.168.1.1
1 ;;; AP "POS" network
192.168.12.0/24 192.168.12.1 192.168.1.1My HOTSPOT configuration :
Flags: X - disabled, I - invalid, S - HTTPS
NAME INTERFACE ADDRESS-POOL PROFILE IDLE-TIMEOUT
0 Hotspot "FREE" Bridge "FREE" default noneMy HOTSPOT PROFILE configuration :
Flags: * - default
0 * name="default" hotspot-address=192.168.11.2 dns-name="" html-directory=hotspot-FREE rate-limit="" http-proxy=0.0.0.0:0 smtp-server=0.0.0.0 login-by=http-chap,trial
split-user-domain=no trial-uptime=1m/2m trial-user-profile=default use-radius=no
The error was wrong GATEWAY in the "DHCP NETWORK" section :
Wrong :
ADDRESS GATEWAY DNS-SERVER WINS-SERVER DOMAIN
Right :
192.168.11.0/24 192.168.11.2 192.168.1.1
