[SOLVED] yet another noob who have problem forwarding port 80 for a webserver
i’m new in mikrotik world, and i’m facing a problem when i want to access my sefthosted web server from local.
My hardware : mikrotik hAP ac2.
ethernet 1 : PPPoE (46.231.XXX.XXX public IP)
ethernet 2 : my homelab, 192.168.0.252 local IP
here my NAT configuration
[admin@MikroTik] > /ip firewall/nat print
Flags: X - DISABLED, I - INVALID; D - DYNAMIC
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface-list=WAN log=no
log-prefix="" ipsec-policy=out,none
1 chain=dstnat action=dst-nat to-addresses=192.168.0.252 to-ports=80
protocol=tcp in-interface-list=WAN dst-port=80 log=no log-prefix=""
2 chain=dstnat action=dst-nat to-addresses=192.168.0.252 to-ports=443
protocol=tcp in-interface-list=WAN dst-port=443 log=no log-prefix=""
3 chain=srcnat action=masquerade src-address=192.168.0.0/24
dst-address=192.168.0.252 log=no log-prefix=""
4 ;;; xmpp
chain=dstnat action=dst-nat to-addresses=192.168.0.252 to-ports=5222
protocol=tcp dst-address=46.231.XXX.XXX dst-port=5222 log=no
log-prefix=""
5 ;;; xmpp
chain=dstnat action=dst-nat to-addresses=192.168.0.252 to-ports=5223
protocol=tcp dst-address=46.231.XXX.XXX src-port="" dst-port=5223 log=no
log-prefix=""
6 ;;; xmpp
chain=dstnat action=dst-nat to-addresses=192.168.0.252 to-ports=5269
protocol=tcp dst-address=46.231.XXX.XXX src-port="" dst-port=5269 log=no
log-prefix=""
XMPP work fine from local or distant network.
i can access my webserver from another network. In local, i have this error :
Failed to establish a secure connection
SSL_ERROR_NO_CYPHER_OVERLAP
I have tried to do like this post but it doesn’t work. I have tried “Hairpin NAT” configuration without understand what i was doing … it doesn’t work …
Any help would be appreciated
You need to move rule 3 to the top. You might also need to make it have action=src-nat and give a specific IP address to use as src (if it doesn't work with masq)
You can turn rules 1 and 2 into a single rule (with multiple ports in the to-ports section)
…by dropping the explicit to-port override, causing RouterOS to leave the port unchanged, yes.
Ditto rules 4-6.
Also, you’re mixing static public IP specification (brittle in a NAT world) with “WAN” interface list specs. Prefer the latter wherever possible.
Regarding hairpin, does connecting via IP give this symptom, or only by domain name?
XMPP works because you use the condition dst-address=46.231.XXX.XXX in the DSTNAT rules related to it.
Your port forwarding of for port 443 and 80 only works from the outside, not from LAN because you use a different condition on them in-interface-list=WAN. With that, DSTNAT only kicks in when the connections come from the other side of the WAN interface, not when you are in your LAN (because in-interface would than be your bridge or local VLANs).
Edit those two DSTNAT rule to remove the condition in-interface-list=WAN and replace that with dst-address=46.231.XXX.XXX.
Specifying dst-address=46.231.XXX.XXX of course is only handy when your public IP address is a static address that rarely changes (otherwise you'd have to edit the rules every time you get a new public IP address). If the public IP address is not static, consider replacing the condition with dst-address-type=local dst-address=!192.168.0.1 (if 192.168.0.1 is the router).
@CGGXANNX thank you ! That was it!
Thank you for the explanations.
I have a public static ip :slight_smile:.
and, just to be sure, if i want to apply rule for multiple ports, i just have use to comma as separator ?
Make a new interface list, like "MYLIST" and add the interfaces to that list as members.
A same interface can be member of more than one list.
Yes, you can consolidate the 5 rules into one single rule, because they all have to same to-addresses value of 192.168.0.252, same protocol=tcp, and do not modify the ports. As for specifying the ports: when entering a command in on the CLI, you can press F1 and see the available syntax most of the time:
so the parameter accepts syntax such as dst-port=12,34,567-678,910,1011-1112.
In your case, when you group the port be aware to:
  • Not specify to-ports (leave the parameter grey in WinBox / not present in the export)
  • Not specify src-port="" like in some of your exported rules above. Having src-port="" like that is wrong and may cause the rules to not match. In WinBox the Src. Port must stay greyed out, not white having an empty string as value!
This rule should be able to replace the 5 original rules:
add chain=dstnat action=dst-nat protocol=tcp \
    dst-address=46.231.XXX.XXX dst-port=80,443,5222,5223,5269 \
But keeping 5 separate rules is fine too and have some advantages, such as having 5 separate traffic counters that allow you to see the individual number of connections being port-forwarded per port. There is not much performance difference between the two approaches, because NAT rules are only evaluated once per connection, and not per each individual packet.
