Someone knows if it is compatible telit lm960 with mikrotik?
great help thanks!!
does the antenna need to be a single 4x4 for CA or can i use 2 of 2x2 antenna like a pair of mikrotik mANT LTE . im running the WAP R and the LTAP mini. and both internal antennas are weak.. a cell phone next to the mikrotik on the internal antenna has better signal, so I lcearly have antenna issues in my testing so we ordered a couple of the mANT to see how they work,
-Christopher
mANT is not directional antenna, you should think about directional antenna and place it into bts dirrection.
Topic of one MIMO4x4 or do 2x(MIMO2x2) is what you should check via your testing. To many differ opinion.
this test system is in a Mobile rig(school bus turned into a mobile DEV lab), I need to use omnidirectional as I cant spend time reidrecting antennas each time I drive and park, directionals would be great if I park for long periods of time or if I was in a seriously weak area and needed to pull down any signal I could..
now for our customer sites, definitely directional is the way we will go if we can.. but often the buildings are such we may only have the ability to locate an antenna in a window and not truly outdoors (in fact most sites).. so we will need omni antenna for those cases.. unless we happen to get a window where we can point to a tower within the antenna field of signal
-Christopher
so im a bit confused.. using an LTAP mini. and an MC7455 sierra or a Telit LM960. do I need to tape the USB3 pins or not? kind of confused on that part.. seems contradicting what I read in various parts of the MT firum about it..
on the LM960 I think i can just use AT commands to srt USB3 off and only use USB2?
is same on MC7455 or I need to tape it?
-Christopher
I not work with any Sierra modules, I not give you answer.
Sometimes software disable usb3.0 give errect like disable to at-chat feature and better is to isolate them.
I see that latest ros7.1beta2 not must be isolate pins, not must software disable usb3.0 and sxtr/lhgr works perfect out-of-box with Quectel modules in MBIM who must have latest own firmware.
I stil havent got Quectel to respond on how to update my firmwares so my card is Useless.. it shipped to me with OLD version and until quectel responds to the many requests ive put in I cant get the tool or the firemware.. im not going to want to use these in my business if thats how they are..
so far Techship has been excellent. my test card is on the way and I already have the tools and documents and firmware files.. so im hopeful it works out on a technical level for us because their customer service is super! the price is a little high but we will likely only use it in areas where its necessary..
-Christopher
Quactel ? Before you write about LM960 who have firmware like here https://techship.com/products/telit-lm960-lte-cat-18-gps-mpcie/ and this is not problem to get it.
Quectel firmware you should get from your distributors because support@quectel.com ask you first from where you buy unit… and then they give you a fw.
edit… ahh, you write about EC25.. still this is firmware needed.
I’ve been using a Telit LM960A18 with a Cradlepoint CBA850 on an AT&T plan for a while now with good results.
I wanted to experiment with a Mikrotik routerboard so purchased a HAP AC2 (RBD52G-5HacD2HnD).
My Telit LM960A18 is installed into a USB > PCIe adapter and when connected to the USB port of my HAP AC2 I dont see any power LEDs or connections in System > Resources.
The modem is configured under windows using Telit’s tool for USB2 mode, pins are not physically isolated.
Any ideas greatly appreciated.
Ive tried powering via to power brick and PoE with a 18v injector.
SOLVED: User error :slight_smile: was connecting via my USB> PCIe adapter USB3port, connecting via USB2 mini-usb it powers up fine.
Hi, I am very interested in guide. Recent I bought RBM33G and I am deciding to buy lm960a18. I already have antenna QuPanel LTE HP MIMO 4x4.
Stojan
maddogslo write:
Check TELIT LM940 HowTo
reviving this old thread.. finally got back to the LM960. ive been using successfully an EM12 Quectel in one LTAP Mini and it works Ok..
updated my other LTAP mini to 7.3 beta40 and connected a couple Paddle antennas.. the LM960 works great now since they made some changes in 7.2,
the only wierd thing is that the LM960 will not work with both SIM slots of an LTAP mini.. I can place a SIM in either slot and it will work.. but when I have both populated with SIMs I cannot get the Lower slot to work..
otherwise the LM960 works fantastic in MBIM mode, the best Module thus far when it comes to LTE data speeds (ive used the MT R11, an EC25-AF, and an EM12, ive also tried a couple Sierra cards but not a lot of joy from those..
would Love to figure out the 2 SIM thing since one of the reasons i use the LTAP mini is for the ability to switch SIM cards.
