Hello everyone!
I use Mikrotik to work as a BRAS in my network diagram, 2 vlans created at eth0, then two pppoe-server interfaces created at the two vlan interfaces respectively, with the same pppoe profile, and at each pppoe-server interface, the keepalive Timeout was 10s.
Mikrotik was connected with another device, the device worked as pppoe-client, which supported vlan too (several pppoe-clients created different vlans).
The problem is:
(1)If the divice started more than one pppoe clients(start these clients synchronously, or at first only one client, after some time, started another client), these pppoe cleints will be dropped(pppoe session was terminated)
(2)If the divice only started one pppoe client, it will not be dropped.
Mikrotik version is V2.9.2
I am puzzled by this problem for a long time, any suggestion was welcome
I put a hub between Mikrotik and this device, from the captured packets, I found that Mikrotik’s LCP Echo Request has some problem, because I set “Keepalive Timeout” to be 10s, so Mikrotik should send out LCP echo request every 10s, but in fact, Mikrotik will send several LCP echo request packets with the peroid 1! After these LCP request packets(without LCP reply), Mikrotik sent out PADT to terminate the pppoe session.
I do not know how to attach a pic here, otherwize it will be more clear, I export the content of packets to txt format, 7 packets captured, the first 5 packets, Mikrotik sent out LCP echo request with peroid 1s, very quickly, the 6th packet, Mikrotik sent out PADT to pppoe client to terminate the pppoe session, the 7th packet, pppoe client agreed to terminate this session.
(Pay attention to timestamp in red lines)
No. Time Source Destination Protocol Info
53 61.184327 HewlettP_04:c8:0d 00:00:00_00:0b:02 PPP LCP Echo Request
Frame 53 (56 bytes on wire, 56 bytes captured)
Ethernet II, Src: HewlettP_04:c8:0d (00:11:85:04:c8:0d), Dst: 00:00:00_00:0b:02 (00:00:00:00:0b:02)
PPP-over-Ethernet Session
Point-to-Point Protocol
PPP Link Control Protocol
Code: Echo Request (0x09)
Identifier: 0x05
Length: 8
Magic number: 0x5ff4ad1b
54 62.194520 HewlettP_04:c8:0d 00:00:00_00:0b:02 PPP LCP Echo Request
Frame 54 (56 bytes on wire, 56 bytes captured)
Identifier: 0x06
Length: 8
55 63.204840 HewlettP_04:c8:0d 00:00:00_00:0b:02 PPP LCP Echo Request
Frame 55 (56 bytes on wire, 56 bytes captured)
Identifier: 0x07
Length: 8
56 64.214907 HewlettP_04:c8:0d 00:00:00_00:0b:02 PPP LCP Echo Request
Frame 56 (56 bytes on wire, 56 bytes captured)
Identifier: 0x08
Length: 8
57 65.225234 HewlettP_04:c8:0d 00:00:00_00:0b:02 PPP LCP Echo Request
Frame 57 (56 bytes on wire, 56 bytes captured)
Identifier: 0x09
Length: 8
58 66.235685 HewlettP_04:c8:0d 00:00:00_00:0b:02 PPPoED Active Discovery Terminate (PADT)
Frame 58 (56 bytes on wire, 56 bytes captured)
PPP-over-Ethernet Discovery
59 66.256247 00:00:00_00:0b:02 HewlettP_04:c8:0d PPPoED Active Discovery Terminate (PADT)
Frame 59 (60 bytes on wire, 60 bytes captured)
Ethernet II, Src: 00:00:00_00:0b:02 (00:00:00:00:0b:02), Dst: HewlettP_04:c8:0d (00:11:85:04:c8:0d)
PPPoE Tags
