Specify a port range!!
I want to create a firewall rule to block ports 1024 to 1862, 1864 to 3127, 3129 to 65535 and I want to specify all these por ranges in only one rule, an not want to create one rule per port range.. It is possible?
Thanks…
I don’t think this is possible in 2.9. Any reason it has to be 1 rule? In the end RouterOS is going to spend just as much time reviewing 1 rule with 3 port ranges as 3 rules with 1 port range each.
Sam
Cant do this in one rule. You need a rule per port.
Specifying ranges simplifies administration, so IMHO it should be added. I see no reason why I must enter 2000 rules to block 2000 ports when it can be done with one rule (regardless how long the router takes to process).
One rule per range of ports. If you want to block 2000 ports and they are all sequential you can use dst-port=1024-3024.
Sam
