Hello
RB2011UAS-RM, RouterOS 6.27 (also tested with 6.24 and 6.13 with same results)
I use proxy for manage access from network to external resources and found this issue.
Speed and ping fall through proxy about five times.
I can understand if ping growth cause it needs time to store and open connection on proxy but why speed fall so dramatically?
Here is speedtest results when using proxy:
http://www.speedtest.net/my-result/4279254355
and only NAT
http://www.speedtest.net/my-result/4279257081
My proxy config is:
/ip proxy
set cache-administrator=proxyadmin@domain.ru cache-path=webproxy enabled=\
yes max-cache-size=10240KiB max-client-connections=1500 max-fresh-time=1d \
max-server-connections=1500 parent-proxy=0.0.0.0 port=3128
/ip proxy access
add src-address=192.168.1.238
add dst-host=*odnoklassniki.ru src-address=192.168.1.58
add dst-host=*vkontakte.ru src-address=192.168.1.58
add dst-host=*my.mail.ru src-address=192.168.1.58
add dst-host=*ozon.ru src-address=192.168.1.58
add dst-host=*bonprix.ru src-address=192.168.1.58
add dst-host=*vk.com src-address=192.168.1.58
add dst-host="\r\
\n*kupivip.ru" src-address=192.168.1.58
add dst-host=*yves-rocher.ru src-address=192.168.1.58
add dst-host=*wildberries.ru src-address=192.168.1.58
add dst-host=*lamoda.ru src-address=192.168.1.58
add action=deny dst-host=*odnoklassniki.ru
add action=deny dst-host=*vkontakte.ru
add action=deny dst-host=*my.mail.ru
add action=deny dst-host=*ozon.ru
add action=deny dst-host=*bonprix.ru
add action=deny dst-host=*vk.com
add action=deny dst-host="\r\
\n*kupivip.ru"
add action=deny dst-host=*yves-rocher.ru
add action=deny dst-host=*wildberries.ru
add action=deny dst-host=*lamoda.ru
add action=deny dst-host=*mamba.ru
add action=deny dst-host=*24open.ru
add action=deny dst-host=*intim-znakomstva.ru
add action=deny dst-host=*dating.ru
add action=deny dst-host=*znakomctba.ru
add action=deny dst-host=*liveinternet.ru
add action=deny dst-host=*maybe.ru
add action=deny dst-host=*javagala.ru
add action=deny dst-host=*znakomstva-sitelove.ru
add action=deny dst-host=*2-polovinka.ru
add action=deny dst-host=*loveplanet.ru
add action=deny dst-host=*youtube.ru
add action=deny dst-host=*mirtesen.ru
add action=deny dst-host=*vkrugudruzei.ru
add action=deny dst-host=*odnoklassniki.km.ru
add action=deny dst-host=*counter.yadro.ru
add action=deny dst-host=*googlesyndication.com
add action=deny dst-host=*radar.imgsmail.ru
add action=deny dst-host=*autocontext.begun.ru
add action=deny dst-host=*tns-counter.ru
add action=deny dst-host=*worka.ru
add action=deny dst-host=*googleadservices.com
add action=deny dst-host=*laredoute.ru
add action=deny dst-host=*otto.ru
add action=deny dst-host=*wenz.ru
add action=deny dst-host=*ads.ookla.com
add action=deny dst-host=*doubleclick.net
add action=deny dst-host=*radio.zaycev.fm
add dst-port=21,443,210,5222,5190,2082,3333,8443,9443,15443 method=CONNECT \
src-address=192.168.1.0/24
add dst-port=36622,28058,4051,4451,10048,1935 method=CONNECT src-address=\
192.168.1.0/24
add dst-port=80,21,443,70,210,280,488,591,777,1025-65535 method=!CONNECT \
add action=deny
