greetings to all, recently purchased access point wap ac, speed measurement showed that it gives 20 Mbps less than the old router from another manufacturer, all tests were performed on 2.4 GHz, disabled the firewall, no special settings are not made,the impact speed is great, the understatement of only the inbound traffic, how to achieve speed as on the old router?
Check the speed you are connected.
I’ve spent many hours trying to get better wifi speeds out of various Mikrotik products. I’ve never gotten anything better than 20mbps for 2.4 Ghz. My solution was to go with another brand for wifi, but I still use Mikrotik for Routing, VPNs, etc.
Others have posted this same problem. I’ve followed their threads and a solution never shows up.
Seems odd, I just installed a cap lite in my lab environment so I thought I’d try this out. I setup iperf on a server in my LAN and ran iperf from my laptop connected to the cap lite.
TCP
[mikrotik@iperf1 ~]$ iperf -s -p 5201 -m
Server listening on TCP port 5201
TCP window size: 85.3 KByte (default)
[ 4] local 10.241.41.186 port 5201 connected with 10.211.11.32 port 2833
[ ID] Interval Transfer Bandwidth
[ 4] 0.0-30.0 sec 201 MBytes 56.1 Mbits/sec
[ 4] MSS size 1460 bytes (MTU 1500 bytes, ethernet)
UDP
[mikrotik@iperf1 ~]$ iperf -s -p 5201 -u
Server listening on UDP port 5201
Receiving 1470 byte datagrams
UDP buffer size: 208 KByte (default)
[ 3] local 10.241.41.186 port 5201 connected with 10.211.11.32 port 55536
[ ID] Interval Transfer Bandwidth Jitter Lost/Total Datagrams
[ 3] 0.0-10.1 sec 113 MBytes 94.3 Mbits/sec 0.610 ms 2339/83022 (2.8%)
/interface wireless registration-table print
8 wlan1 YY:YY:YY:XX:XX:XX no -59dBm@HT40-6 180M... 13m7s
))) - ethernet - - ethernet - <hex, intervlan routing> - ethernet - - ethernet - - linux bridge - <iperf vm, single core, 1024mb of ram>
I didn’t do anything fancy and it “just works.” Additionally, it’s one of the cheapest APs available.
What are your wireless settings? I tested another cap lite this morning and at best it gave me 17 mbps. I’ve tried this and that, compared brands, I can’t get the cap lites to break 25mbps. I’d love to figure this out!!
6.40rc38 (new bridge implementation, won’t upgrade the unit until 6.41rc)
Interface Export
# model = RouterBOARD cAP L-2nD
add admin-mac=xx:xx:xx:yy:yy:yy auto-mac=no fast-forward=no igmp-snooping=no name=br1
add authentication-types=wpa2-psk mode=dynamic-keys name=MyFirstSSID wpa2-pre-shared-key=MyFirstSSIDPassword
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce country="united states3" disabled=no distance=indoors frequency=auto mode=ap-bridge multicast-helper=full rx-chains=0,1 \
security-profile=MyFirstSSID ssid=MyFirstSSID tx-chains=0,1 wireless-protocol=802.11
add bridge=br1 hw=no interface=wlan1
add bridge=br1 interface=ether1
Remember, wireless is finicky. If you live in an area with high interference that can be a major problem. Additionally, the hardware you connect with can equally be at fault. It’s not uncommon to see different wireless firmware or drivers behave differently.
