Not sure what I might be doing wrong but hAP ax2 UDP Upload test is low when testing from Router speedtest tool (Console) to Btest/server on PC.
Doesn’t seem to matter if it’s wired or wireless.
tool/speed-test address=Local
status: done
time-remaining: 0s
ping-min-avg-max: 1.75ms / 2.62ms / 3.89ms
jitter-min-avg-max: 1us / 267us / 1.42ms
loss: 0% (0/200)
tcp-download: 699Mbps local-cpu-load:62%
tcp-upload: 730Mbps local-cpu-load:35% remote-cpu-load:1%
udp-download: 589Mbps local-cpu-load:29% remote-cpu-load:1%
udp-upload: 5.88Mbps local-cpu-load:3% remote-cpu-load:1%
status: done
time-remaining: 0s
ping-min-avg-max: 792us / 1.35ms / 3.55ms
jitter-min-avg-max: 0s / 222us / 2.57ms
loss: 0% (0/200)
tcp-download: 931Mbps local-cpu-load:71%
tcp-upload: 933Mbps local-cpu-load:73% remote-cpu-load:1%
udp-download: 941Mbps local-cpu-load:43% remote-cpu-load:1%
udp-upload: 6.95Mbps local-cpu-load:3% remote-cpu-load:1%
Can you perform a test with two machines, using i.e. iperf?
It would seem so.
I'm getting some strange results, So I'm testing from a PC to pi4 8GB. I'm going to spin up another server later to test again.
If I use multiple streams Linux to Linux? WSL I'm loosing as you can see below But.... If I test again from pi4 to PC iperf3.exe using
UDP single stream 100M if works fine! second set of tests.
pi4 has iperf3 version 3.6 (something-something fixed in version 3.10 UDP Multi) hence i want to spin up another server.
PC has WSL Ubuntu - Hyper-V shared connection iperf3 version 3.13
I need a better match to make sure what I'm seing isn't an iperf -v mismatch problem.
iperf3 -c 192.168.0.104 -P 10 -b 10M -R
[SUM] 0.00-10.00 sec 16.9 MBytes 14.1 Mbits/sec 2563 sender
[SUM] 0.00-10.00 sec 16.0 MBytes 13.4 Mbits/sec receiver
[SUM] 0.00-10.00 sec 120 MBytes 100 Mbits/sec 8 sender
[SUM] 0.00-10.00 sec 120 MBytes 100 Mbits/sec receiver
If I do the same test single stream Linux to iperf3.exe I get this..
iperf3 -c -p 5201 -b 100M -u
Connecting to host , port 5201
[ 5] local port 60825 connected to port 5201
[ ID] Interval Transfer Bitrate Total Datagrams
[ 5] 0.00-1.00 sec 11.9 MBytes 99.9 Mbits/sec 8626
[ 5] 1.00-2.00 sec 11.9 MBytes 100 Mbits/sec 8633
[ 5] 2.00-3.00 sec 11.9 MBytes 100 Mbits/sec 8633
[ 5] 3.00-4.00 sec 11.9 MBytes 100 Mbits/sec 8632
[ 5] 4.00-5.00 sec 11.9 MBytes 100 Mbits/sec 8634
[ 5] 5.00-6.00 sec 11.9 MBytes 100 Mbits/sec 8632
[ 5] 6.00-7.00 sec 11.9 MBytes 100 Mbits/sec 8633
[ 5] 7.00-8.00 sec 11.9 MBytes 100 Mbits/sec 8633
[ 5] 8.00-9.00 sec 11.9 MBytes 100 Mbits/sec 8632
[ 5] 9.00-10.00 sec 11.9 MBytes 100 Mbits/sec 8633
[ ID] Interval Transfer Bitrate Jitter Lost/Total Datagrams
[ 5] 0.00-10.00 sec 119 MBytes 100 Mbits/sec 0.000 ms 0/86321 (0%) sender
[ 5] 0.00-10.00 sec 119 MBytes 99.6 Mbits/sec 0.137 ms 324/86319 (0.38%) receiver
iperf3 -c -p 5201 -b 100M -u -R
Reverse mode, remote host is sending
[ 5] local port 46993 connected to port 5201
[ 5] 0.00-1.00 sec 11.6 MBytes 97.1 Mbits/sec 0.144 ms 0/8381 (0%)
[ 5] 1.00-2.00 sec 12.0 MBytes 100 Mbits/sec 0.241 ms 0/8656 (0%)
[ 5] 2.00-3.00 sec 12.1 MBytes 102 Mbits/sec 0.148 ms 0/8786 (0%)
[ 5] 3.00-4.00 sec 11.9 MBytes 99.6 Mbits/sec 0.144 ms 0/8599 (0%)
[ 5] 4.00-5.00 sec 11.9 MBytes 99.6 Mbits/sec 0.138 ms 0/8598 (0%)
[ 5] 5.00-6.00 sec 11.8 MBytes 99.1 Mbits/sec 0.160 ms 0/8559 (0%)
[ 5] 6.00-7.00 sec 12.1 MBytes 101 Mbits/sec 0.163 ms 0/8758 (0%)
[ 5] 7.00-8.00 sec 11.8 MBytes 99.1 Mbits/sec 0.181 ms 0/8551 (0%)
[ 5] 8.00-9.00 sec 12.1 MBytes 102 Mbits/sec 0.151 ms 0/8788 (0%)
[ 5] 9.00-10.00 sec 11.7 MBytes 98.1 Mbits/sec 0.156 ms 0/8467 (0%)
[ 5] 0.00-10.00 sec 119 MBytes 99.8 Mbits/sec 0.000 ms 0/86166 (0%) sender
[ 5] 0.00-10.00 sec 119 MBytes 99.8 Mbits/sec 0.156 ms 0/86143 (0%) receiver
i'm not sure Windows iperf3 does -P properly at all.
I'll pop back when I've got more clean results
@erlinden
Test to a proper linux server (iperf3 v 3.9) gives me no such nonsense.
So that would be a no it doesn’t do the same thing.
iperf3 -c 192.168.0.22 -P 10 -b 50M -u -R
[SUM] 0.00-10.01 sec 597 MBytes 500 Mbits/sec 0.000 ms 0/432120 (0%) sender
[SUM] 0.00-10.00 sec 596 MBytes 500 Mbits/sec 0.291 ms 0/431855 (0%) receiver
[SUM] 0.00-10.00 sec 596 MBytes 500 Mbits/sec 0.000 ms 0/431600 (0%) sender
[SUM] 0.00-10.01 sec 594 MBytes 497 Mbits/sec 0.186 ms 1727/431593 (0.4%) receiver
1 test from the server just to check
iperf3 -c 192.168.0.104 -P 10 -b 50M
[SUM] 0.00-10.00 sec 597 MBytes 501 Mbits/sec 4 sender
[SUM] 0.00-10.02 sec 597 MBytes 500 Mbits/sec receiver
oops try that again that last 1 was tcp…
iperf3 -c 192.168.0.104 -P 10 -b 50M -u
[SUM] 0.00-10.00 sec 595 MBytes 499 Mbits/sec 0.271 ms 674/431595 (0.16%) receiver
Works fine from Mikrotik >> Mikrotik
status: done
time-remaining: 0s
ping-min-avg-max: 145us / 214us / 436us
jitter-min-avg-max: 0s / 20us / 291us
loss: 0% (0/200)
tcp-download: 929Mbps local-cpu-load:59%
tcp-upload: 932Mbps local-cpu-load:42% remote-cpu-load:87%
udp-download: 943Mbps local-cpu-load:26% remote-cpu-load:58%
udp-upload: 956Mbps local-cpu-load:37% remote-cpu-load:47%
Just not Mikrotik to Windows btest/server, another PC fresh install same thing
status: done
time-remaining: 0s
ping-min-avg-max: 374us / 424us / 862us
jitter-min-avg-max: 0s / 26us / 441us
loss: 0% (0/200)
tcp-download: 942Mbps local-cpu-load:47%
tcp-upload: 933Mbps local-cpu-load:42% remote-cpu-load:6%
udp-download: 938Mbps local-cpu-load:27% remote-cpu-load:6%
udp-upload: 6.85Mbps local-cpu-load:2% remote-cpu-load:6%
So I’m out of Ideas.
That’s why it was suggested to use iperf on both sides passing over that Tik router.
My go to tool for such cases is always iperf3 in container or bare metal (and HE.NET app on Android if needed).
I wasn’t aware that it didn’t work properly Windows btest.exe.
erm.. how about x86 Mikrotik in a VM would that work properly ?
Depends on the CPU you have on that VM and the available network card.
There is a public Btest server available hosted by our own North Idaho Tom Jones, if you want.
I believe it can digest up to several Gbps
http://forum.mikrotik.com/t/public-mikrotik-bandwidth-test-server-s-now-shutdown-as-of-april-1st-2025/94863/1
If only I had that much bandwidth
27 Mbps… meh
Ok so installed Hyper-V then CHR on Windows11 yup Windows11 it works now I guess.
https://www.youtube.com/watch?v=RQ-52Ih_MmQ
But guess what, it’s the same as btest.exe oh well more useless info gained so someone else doesn’t need to.
It works very well guys, big thumbs up
