Splitting/parsing variable data
What is the command equivalent of bash awk or cut? I found the “:parse” function but am unable to get that to succeed.
When I run the following command:
:put [/system resource get version]
I see something like:
6.44.5 (long-term)
I want to return only the version number. That is, use the space as the delimiter.
Thank you! :slight_smile:
This should do:
:local ver [/system resource get version]
:put [:pick $ver 0 [:find $ver " "]]
:local ver [/system resource get version] Get the line
[:find $ver " "] gets position of space
[:pick $ver 0 [:find $ver " "]] get text from position 0 to first space
See manual here:
https://wiki.mikrotik.com/wiki/Manual:Scripting
find :find return position of substring or array element :put [:find “abc” “a” -1]
pick :pick [] return range of elements or substring. If end position is not specified, will return only one element from an array. :put [:pick “abcde” 1 3]
It would be nice when the scripting language was extended with some features known from e.g. Perl, like “split” and “regexp match with capture”.
These operations would take a line of characters and either a splitting character (like a space in your case) or a regular expression describing the line and what you want to get from it, and return the results as an array holding the extracted fields.
Until then, indeed you will have to use (possibly repeated) use of find and pick.
Thank you!
Hi all,
I also need a script to parse data from comments in secrets.
As an example:
Comment secret A:
081234567890|West Java|John Due
Comment secret B:
08123456789|East Java|Michael Jackson
Comment secret C:
0812345678901|Central Java|Clara Bernadeth
And using “|” as a separator.
How do I retrieve telephone, address and name data if the data is random like the example above?
Thank you
:local test “081234567890|West Java|John Due”
:put [:pick $test ( -1 + 1) [:find $test “|” -1] ]
:put [:pick $test ( [:find $test “|” -1] + 1) [:find $test “|” [:find $test “|” -1]] ]
:put [:pick $test ( [:find $test “|” [:find $test “|” -1]] + 1) [:len $test ] ]
Hi Rex,
Could you explain this part of the script? (I see that it is to get the second character "|" but I do not understand it.
[:find $test "|" [:find $test "|" -1]]
Tnx.
The spaces were not placed by chance…
If [:find $test “|” -1] identify the position of the first “|”
([:find $test “|” -1] + 1) is the next character from the |
so if you start the next :find from ([:find $test “|” -1] + 1) you obtain the next “|”, etc…
:put [:pick $test (-1 + 1) [:find $test “|” -1] ]
:put [:pick $test ([:find $test “|” -1] + 1) [:find $test “|” [:find $test “|” -1]] ]
:put [:pick $test ([:find $test “|” [:find $test “|” -1]] + 1) [:len $test ] ]
so, if you add another item:
:local test "081234567890|West Java|John Due|another one"
:local s    "|" ; # separator
:put [:pick $test (                                                -1    + 1)                                 [:find $test $s -1]   ]
:put [:pick $test (                                [:find $test $s -1]   + 1)                 [:find $test $s [:find $test $s -1]]  ]
:put [:pick $test (                [:find $test $s [:find $test $s -1]]  + 1) [:find $test $s [:find $test $s [:find $test $s -1]]] ]
:put [:pick $test ([:find $test $s [:find $test $s [:find $test $s -1]]] + 1)                                 [:len  $test      ]   ]
A little difficult but with your excellent explanation I understand.
Thank you magister!
Is just an example for a little complex string, if the fields are more, a cycle is better…
What would be the way to do it without pick?
I have tried as an array but only "the comma" works as a separator between values. The vertical bar does not work.
:local test [:toarray "081234567890|West Java|John Due|Another one|Second item"]
:put ($test->0)
:put ($test->1)
:put ($test->2)
:put ($test->3)
:put ($test->4)
excuse my ignorance.
BR.
Using :toarray “trick” to parse a delimated string doesn’t know about | being a separator. By “cycle”, that means a “:for” loop with a :pick and :find inside…since :toarray isn’t really a parser, it just conveniently use comma in syntax to define elements .
I can (uselessly) write a method for not use at all pick for split a string, but if pick exist, why not use it?
For convert x|y|z on one array of 3 elements, two way are simpler: first replace inside the string all | with , and use :toarray
or use a “while” until you do not process the string from the start to the end and create a new string inside the array fore each | and the last at the end of the string.
Normally the reason to use some separator is because it is known that this separator cannot occur in the data.
I often use but in this case apparently | was chosen. I would not want to change all | to , and then use :toarray, it may well be that some fields between the | separators can have , in the value, and chaos would result.
What we really need is script functions that can convert a line to an array using user-defined separator or better: regexp with capture.
At one time we were promised a script library with useful functions like that…
FWIW, I put in a feature request on the v7.13beta’s :serialize and :deserialize to add support for “delimited file” (CSV/TSV/etc). While the new commands add JSON in beta, they do support a from= and to=…
But… I’d agree a :regexp command (with capture/grouping) that be similar to sed be useful & also solve parsing string more generically.
Not, just simply replace that “,” with (for example) $$$comma$$$ and when array is created, convert back $$$comma$$$ to “,” on each item.
Thank you all for your advice.
BR.
Something like that, right?
:local string "081234567890|West Java|John Due|Another one|Second item"
:local reEncoded
:for i from=0 to=([:len $string] - 1) do={
    :local char [:pick $string $i]
    :if ($char = "|") do={:set $char ","}
    :set reEncoded ($reEncoded . $char)
:local test [:toarray $reEncoded]
:put ($test->0)
:put ($test->1)
:put ($test->2)
:put ($test->3)
:put ($test->4)
Output:
081234567890
West Java
John Due
Another one
Second item
I have adapted this function that I have found in the Scripting forum and that is valid for what I need, I share it.
:global strEncode do={
    :local string $1
    :local reEncoded
    :local char
    :if (([:typeof $string] != "str") or ($string = "")) do={
        :return ""
    } else={
        :for i from=0 to=([:len $string] -1) do={
            :set char [:pick $string $i]
            :if ($char = "!") do={:set $char ","}
        :return $reEncoded
Use:
:put [$strEncode "081234567890|West Java|John Due|Another one!Second item"]
Output:
081234567890,West Java,John Due,Another one,Second item
Remember that this is a recipe for “injection attacks” similar to the wellknown “SQL injection attacks” that are so often used to hack websites, online stores, etc., and also like using eval() to quickly parse JSON data into JavaScript.
This can really only be used when the data to be parsed can be fully trusted, not when there is any possibility that an outsider could modify the data e.g. via a form or some other data entry.
The data used is for learning use only.
