splitting up an assigned block of IP's in MT
Let’s say I have a /27 block of ip’s to my MT… how can I split that in half for another device connected to the MT
Internet ---- > MT -----> AP
thanks
If the entire /27 is routed from your ISP to your MT, you can do whatever you want from the MT and beyond. You could make one /28 and two /29, four /29, eight /30, etc.
I suggest you go here to calculate your subnets:
http://www.subnet-calculator.com/
Additionally, it would help to read the RouterOS manual on routing:
http://www.mikrotik.com/testdocs/ros/2.9/ip/route.php
