This is SideA for example, let me know if you would like me to paste the routing of SideB too.
[admin@AA] /ip route> /export
jan/01/2002 03:08:08 by RouterOS 3.17
software id = RDCG-3TT
set 0 arp=enabled auto-negotiation=yes comment="" disabled=no full-duplex=yes mac-address= mtu=1500 name=Lan1 speed=100Mbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=yes full-duplex=yes mac-address=00:0C:42:0B:73:C2 master-port=none mtu=1500 name=ether2 speed=100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=yes full-duplex=yes mac-address= master-port=none mtu=1500 name=ether3 speed=100Mbps
set default authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip group-key-update=5m interim-update=0s mode=none name=default radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no
radius-mac-caching=disabled radius-mac-format=XX:XX:XX:XX:XX:XX radius-mac-mode=as-username static-algo-0=none static-algo-1=none static-algo-2=none static-algo-3=none static-key-0="" static-key-1=""
static-key-2="" static-key-3="" static-sta-private-algo=none static-sta-private-key="" static-transmit-key=key-0 supplicant-identity=MikroTik tls-certificate=none tls-mode=no-certificates unicast-ciphers=tkip
wpa-pre-shared-key=mikr0tik wpa2-pre-shared-key=******
add authentication-types=wpa-psk,wpa2-psk group-ciphers=tkip group-key-update=5m interim-update=0s mode=dynamic-keys name=WPA2 radius-eap-accounting=no radius-mac-accounting=no radius-mac-authentication=no
static-key-2="" static-key-3="" static-sta-private-algo=none static-sta-private-key="" static-transmit-key=key-0 supplicant-identity="" tls-certificate=none tls-mode=no-certificates unicast-ciphers=tkip
wpa-pre-shared-key=mikrotik wpa2-pre-shared-key=*****
/interface wireless
set 0 ack-timeout=dynamic adaptive-noise-immunity=none allow-sharedkey=no antenna-gain=0 antenna-mode=ant-a area="" arp=enabled band=5ghz basic-rates-a/g=6Mbps basic-rates-b=1Mbps burst-time=disabled comment=""
compression=no country="south africa" default-ap-tx-limit=0 default-authentication=yes default-client-tx-limit=0 default-forwarding=yes dfs-mode=none disable-running-check=no disabled=no disconnect-timeout=3s
frame-lifetime=0 frequency=5700 frequency-mode=manual-txpower hide-ssid=no hw-retries=4 mac-address= max-station-count=2007 mode=ap-bridge mtu=1500 name=WLan1 noise-floor-threshold=default
on-fail-retry-time=100ms periodic-calibration=default periodic-calibration-interval=60 preamble-mode=both proprietary-extensions=post-2.9.25 radio-name=AA rate-set=default scan-list=default security-profile=
default ssid=Lab station-bridge-clone-mac=00:00:00:00:00:00 supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps supported-rates-b=1Mbps,2Mbps,5.5Mbps,11Mbps tx-power-mode=default
update-stats-interval=disabled wds-cost-range=50-150 wds-default-bridge=none wds-default-cost=100 wds-ignore-ssid=no wds-mode=disabled wmm-support=enabled
/interface wireless manual-tx-power-table
set WLan1 comment="" manual-tx-powers="1Mbps:17,2Mbps:17,5.5Mbps:17,11Mbps:17,6Mbps:17,9Mbps:17,12Mbps:17,18Mbps:17,24Mbps:17,36Mbps:17,48Mbps:17,54Mbps:17,HT20-1:0,HT20-2:0,HT20-3:0,HT20-4:0,HT20-5:0,HT20-6:0,HT20
-7:0,HT20-8:0,HT40-1:0,HT40-2:0,HT40-3:0,HT40-4:0,HT40-5:0,HT40-6:0,HT40-7:0,HT40-8:0"
/interface wireless nstreme
set WLan1 comment="" disable-csma=no enable-nstreme=no enable-polling=yes framer-limit=3200 framer-policy=none
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no
use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 disabled=no enc-algorithms=3des lifetime=30m name=default pfs-group=modp1024
/port
set 0 baud-rate=auto data-bits=8 flow-control=none name=serial0 parity=none stop-bits=1
/ppp profile
set default change-tcp-mss=yes comment="" name=default only-one=default use-compression=default use-encryption=default use-vj-compression=default
set default-encryption change-tcp-mss=yes comment="" name=default-encryption only-one=default use-compression=default use-encryption=yes use-vj-compression=default
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set default-small kind=pfifo name=default-small pfifo-limit=10
/routing bgp instance
set default as=65530 client-to-client-reflection=yes comment="" disabled=no ignore-as-path-len=no name=default out-filter="" redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=no
redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
add area-id=0.0.0.0 authentication=none disabled=no name=backbone type=default
/snmp
set contact="" enabled=no engine-boots=0 engine-id="" location="" time-window=15 trap-sink=0.0.0.0 trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password="" authentication-protocol=MD5 encryption-password="" encryption-protocol=DES name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-lines=100 disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote name=remote remote=0.0.0.0:514 target=remote
/system routerboard settings
set baud-rate=115200 boot-delay=2s boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=300MHz enable-jumper-reset=yes enter-setup-on=any-key
/user group
add name=read policy=local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,!ftp,!write,!policy
add name=write policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,sniff,!ftp,!policy
add name=full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff
/user
add address=0.0.0.0/0 comment="system default user" disabled=no group=full name=admin
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-vlan=no
/interface ethernet mirror
set mirror-port=none source-port=none
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60 mac-address=FE:D7:22:1A:5C:0A max-mtu=1500 mode=ip netmask=24 port=1194
require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/interface wireless align
set active-mode=yes audio-max=-20 audio-min=-100 audio-monitor= filter-mac=00:00:00:00:00:00 frame-size=300 frames-per-second=25 receive-all=yes ssid-all=yes
/interface wireless sniffer
set channel-time=200ms file-limit=10 file-name="" memory-limit=10 multiple-channels=no only-headers=no receive-errors=no streaming-enabled=no streaming-max-rate=0 streaming-server=0.0.0.0
/interface wireless snooper
set channel-time=200ms multiple-channels=yes receive-errors=no
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.21.1/24 broadcast=192.168.21.255 comment="" disabled=no interface=WLan1 network=192.168.21.0
add address=192.168.2.180/24 broadcast=192.168.2.255 comment="" disabled=no interface=Lan1 network=192.168.2.0
/ip dhcp-server config
set store-leases-disk=5m
set allow-remote-requests=no cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=512 primary-dns=0.0.0.0 secondary-dns=0.0.0.0
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s
tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set Lan1 discover=yes
set ether2 discover=yes
set ether3 discover=yes
set WLan1 discover=no
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no enabled=no max-cache-size=unlimited max-client-connections=600 max-fresh-time=3d max-server-connections=600 parent-proxy=
0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=no src-address=0.0.0.0
add disabled=no distance=1 dst-address=192.168.1.0/24 gateway=192.168.21.2 scope=30 target-scope=10
/ip route rule
add action=lookup comment="" disabled=no dst-address=192.168.1.0/24 table=main
/ip service
set telnet address=0.0.0.0/0 disabled=no port=23
set ftp address=0.0.0.0/0 disabled=no port=21
set www address=0.0.0.0/0 disabled=no port=80
set ssh address=0.0.0.0/0 disabled=no port=22
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=yes port=8728
set winbox address=0.0.0.0/0 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=no inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/ipv6 nd
add advertise-mac-address=yes disabled=no hop-limit=unspecified interface=all mtu=unspecified ra-delay=3s ra-interval=3m20s-10m ra-lifetime=30m reachable-time=unspecified retransmit-interval=unspecified
/ipv6 nd prefix default
set autoconfig=yes on-link=yes preferred-lifetime=1w valid-lifetime=4w2d
/mpls
set dynamic-label-range=16-1048575
/mpls interface
add comment="" disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 use-explicit-null=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set Lan1 queue=ethernet-default
set ether2 queue=ethernet-default
set ether3 queue=ethernet-default
set WLan1 queue=wireless-default
/radius incoming
set accept=no port=3799
/routing igmp-proxy
set query-interval=2m5s query-response-interval=10s quick-leave=no
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m gateway-selection=no-gateway origination-interval=5s preferred-gateway=0.0.0.0 timeout=1m ttl=50
/routing ospf
set distribute-default=always-as-type-1 metric-bgp=20 metric-connected=20 metric-default=1 metric-rip=20 metric-static=20 mpls-te-area=unspecified mpls-te-router-id=unspecified redistribute-bgp=no
redistribute-connected=as-type-1 redistribute-rip=no redistribute-static=as-type-1 router-id=0.0.0.0
/routing pim
set switch-to-spt=no switch-to-spt-bytes=0 switch-to-spt-interval=0s
/routing rip
set distribute-default=always garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no redistribute-connected=yes redistribute-ospf=no
redistribute-static=yes timeout-timer=3m update-timer=30s
/routing rip neighbor
add address=192.168.1.180 disabled=no
/routing ripng
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no redistribute-connected=no redistribute-ospf=no redistribute-static=
no timeout-timer=3m update-timer=30s
/store
add comment="" disabled=no disk=system name=user-manager1 type=user-manager
add comment="" disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start="jan/01/1970 00:00:00" time-zone=+00:00
/system console
add disabled=no port=serial0 term=vt102
/system gps
set enabled=no set-system-time=yes
/system health
set fan-mode=auto use-fan=main
/system identity
set name=AA
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=no mode=unicast primary-ntp=196.4.160.4 secondary-ntp=0.0.0.0
/system ntp server
set broadcast=no enabled=no manycast=yes multicast=no
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=no no-ping-delay=3m send-email-from=1 send-email-to=1 watch-address=none watchdog-timer=no
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=10
/tool e-mail
/tool graphing
set store-every=5min
/tool mac-server
add disabled=no interface=all
/tool mac-server ping
set enabled=yes
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535 filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=yes interface=all memory-limit=10 only-headers=no streaming-enabled=no
/tool user-manager customer
add comment="" disabled=no login=admin parent=admin password="" paypal-accept-pending=no paypal-allowed=no paypal-secure-response=no permissions=owner signup-allowed=no subscriber=admin time-zone=+00:00
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
Thanks again for your effort to assist me
