SSH connect to local server and forwarding torrents ports
I bought new 951G-2HnD today and can’t set it up right.
I have local web server, it should receive all incoming port=80 and port=12345 (ssh) connections. I have torrents on my laptop. I want to be able to ssh-connect from laptop to server through local network.
Here what I have so far:
// rule for local clients to internet:
add action=masquerade chain=srcnat comment=“default configuration” out-interface=ether1-gateway
// rules for tcp and udp from internet with ports=80,12345 (5.120.90.10 is my static ip address, 192.168.88.2 is server’s local ip):
add action=dst-nat chain=dstnat dst-address=5.120.90.10 dst-port=80,12345 protocol=tcp to-addresses=192.168.88.2
add action=dst-nat chain=dstnat dst-address=5.120.90.10 dst-port=80,12345 protocol=udp to-addresses=192.168.88.2
// rule for server response to local clients:
add action=masquerade chain=srcnat src-address=192.168.88.0/24 protocol=tcp dst-port=80,12345
// the last non-working rule for forwarding any other port (torrents) to laptop (it’s local ip 192.168.88.10):
add action=dst-nat chain=dstnat disabled=yes dst-port=!80,12345 protocol=tcp to-addresses=192.168.88.10
If I enable the last rule, torrent client works and internet disappears. How to write it right?
Also, I can’t ssh-connect to my local server. I can connect to it through other, remote machine? but direct connection through lan (like ssh user@192.168.88.2 -p 12345) does not work.
you forgot your public IP in this rule - as written, it will dst-nat all outbound traffic back to your laptop, except ports 80 and 12345.
put dst-address=5.120.90.10 on this rule as well, and it’ll be fixed.
Can’t say about the internal SSH problem, though - such connections shouldn’t even go through the Mikrotik at all… as long as the internal hosts are using the 192.168.88.2 address as your example states. Check the server for any iptables rules or configs in sshd that would disallow connections from 192.168.88.x
Thanks a lot! You are right twice, I forgot about allowusers setting in my sshd config (I had 192.168.1.* local network with my previous router, and now it’s 192.168.88.*)
