I’m trying to access a raspberry pi in a local network behind a Mikrotik SXT LTE using the SSH protocol, but I can’t. The Mikrotik replaces a TP-Link that was fine in the same task. After trying to configure the NAT in different ways, using the configuration in the documentation, in some posts refering to this issue, changing diverse parameters, etc., there is no way to access from internet to my local server. The traffic this NAT rule always shows 0 bytes.
The ingoing port is 2022 (and I tried with different numbers without success) and the idea is to traslate to the port 22.
Any suggestion or idea to test the problem?
Toni
