SSH is not working
Hy!
I want to connect via SSH from the laptop to the mikrotik router on the same network. I can ping. Login is possible with Winbox, but SSH times out. It is enabled in the IP/SERVICE menu. I have no idea why I can’t log in. Did I disable it with something? I am attaching a terminal command. I would be happy to receive advice and help.
THX!
add comment=defconf name=bridge
add name=wifi-bridge
/interface wireless
set [ find default-name=wlan1 ] name=wlan3 ssid=MikroTik
set [ find default-name=ether1 ] mac-address=C4:AD:34:E0:DB:FB
set [ find default-name=ether2 ] mac-address=C4:AD:34:E0:DB:FC
set [ find default-name=ether3 ] mac-address=C4:AD:34:E0:DB:FD
/interface pwr-line
set [ find default-name=pwr-line1 ] mac-address=C4:AD:34:E0:DC:1C
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=Controller ranges=10.99.99.10
add name=NGBS ranges=10.99.99.20
add name=WIFI ranges=10.99.99.30-10.99.99.40
add address-pool=NGBS disabled=no interface=bridge name=defconf
add address-pool=WIFI disabled=no interface=wifi-bridge name=Wifi
/user group
set full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,pas\
    sword,web,sniff,sensitive,api,romon,dude,tikapp"
add bridge=bridge comment=defconf interface=pwr-line1
add bridge=bridge comment=defconf interface=*5
add bridge=wifi-bridge interface=*7
add address=10.99.99.1/24 comment=defconf interface=bridge network=10.99.99.0
add address=10.99.99.1/24 interface=wifi-bridge network=10.99.99.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
add address=10.99.99.0/24 comment=defconf gateway=10.99.99.1
/ip dhcp-server vendor-class-id
add address-pool=Controller name=chameleon vid=\
    dhcpcd-8.1.2:Linux-4.19.97-v7+:armv7l:BCM2835
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment="allow winbox from inet" dst-port=8291 \
    protocol=tcp
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=dst-nat chain=dstnat comment="NGBS master - iCon" dst-port=502 \
    in-interface=ether1 protocol=tcp to-addresses=10.99.99.20 to-ports=502
/system clock
set time-zone-name=Europe/Budapest
/tool mac-server
/tool mac-server mac-winbox
Show your /ip services export
[admin@MikroTik] > /ip service print
 #   NAME           PORT ADDRESS                                             CERTIFICATE
 0   telnet           23
 1   ftp              21
 2   www              80
 3   ssh              22
 4 XI www-ssl         443                                                     none
 5   api            8728
 6   winbox         8291
 7   api-ssl        8729                                                     none
[admin@MikroTik] >
I’m suprised you have any connectivity at all as you have two networks with the same address. Use a single bridge.
