SSH Problem: ssh_exchange_identification
got same strange behaviour just after adding another user and its ssh key, thats second ssh key I added, before that all ssh connections was OK
while experimanting with ssh access to RB for scripting got this, for example:
$ sudo -u nobody ssh -i /tmp/id_dsa.pub openvpn@m66 -vvv
OpenSSH_6.6.1, OpenSSL 1.0.1f 6 Jan 2014
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug2: ssh_connect: needpriv 0
debug1: Connecting to m66 [X.X.X.X] port 22.
debug1: connect to address X.X.X.X port 22: Connection timed out
ssh: connect to host m66 port 22: Connection timed out
another one:
$ sudo -u nobody ssh -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -o IdentityFile=/etc/openvpn/keys/id_dsa.pub -o UserKnownHostsFile=/etc/openvpn/keys/known_hosts -vvvvvv openvpn@gw.m66
OpenSSH_5.3p1, OpenSSL 1.0.1e-fips 11 Feb 2013
debug1: Applying options for *
debug1: Executing proxy command: exec /usr/bin/sss_ssh_knownhostsproxy -p 22 gw.m66
debug1: permanently_drop_suid: 99
Could not create directory '/.ssh'.
debug3: Not a RSA1 key file /etc/openvpn/keys/id_dsa.pub.
debug1: identity file /etc/openvpn/keys/id_dsa.pub type 2
debug1: identity file /etc/openvpn/keys/id_dsa.pub-cert type -1
ssh_exchange_identification: Connection closed by remote host
and another:
$ ssh -i id_dsa.pub openvpn@gw.m66 -vvv
debug1: permanently_drop_suid: 2525
debug3: Not a RSA1 key file id_dsa.pub.
debug1: identity file id_dsa.pub type 2
debug1: identity file id_dsa.pub-cert type -1
and soon later I was surprised by finding what no ssh connections are possible for some IPs on RB interfaces, thanks god I found one IP on vlan interface for which ssh connection was possible to reboot router
check if your SSH is still supporting DSA keys. The latest trend is to remove it in various Linux distros. As SSH 7.x suggests to do just that.
Centos 6 and Ubuntu 14.04 ok with dsa as I can see …
still there is no reason for ssh on RB2011 to fail! will you fix your ssh some day?
Run WinBox
IP> Service> SSH> Check port, and also check Available from, remove all IP if there are any.
Then try SSH again
