I noticed a regression in RouterOS beta/rc up to rc1 in the way SSH server handles SSH protocol.
After some debugging I found out that the SSH server is not answering with either SSH_MSG_CHANNEL_SUCCESS or SSH_MSG_CHANNEL_FAILURE to the SSH_MSG_CHANNEL_REQUEST message, although it is sending the output as channel data.
OpenSSH outputs the data anyway, so the issue is not immediately visible with it.
OTOH ruby’s net-ssh doesn’t start collecting response data unless success message is received leading to empty output being read.
The ruby’s code is the following:
Net::SSH.start(‘192.168.88.1’, ‘admin+ct’, :password => ‘xxxxx’, :config => false, :auth_methods => [‘password’], :verbose => Logger::DEBUG) do |ssh|
puts ssh.exec!(“/interface print”)
end
Relevant log of a working session (RouterOS 4.5):
I, [2010-09-24T14:14:41.792070 #23692] INFO – net.ssh.connection.session[1074e7c]: channel_open_confirmation: 0 0 0 16384
I, [2010-09-24T14:14:41.792146 #23692] INFO – net.ssh.connection.channel[1074c74]: sending channel request “exec”
I, [2010-09-24T14:14:41.802396 #23692] INFO – net.ssh.connection.session[1074e7c]: channel_window_adjust: 0 +32768
I, [2010-09-24T14:14:41.802561 #23692] INFO – net.ssh.connection.session[1074e7c]: channel_success: 0
I, [2010-09-24T14:14:41.838633 #23692] INFO – net.ssh.connection.session[1074e7c]: channel_request: 0 exit-status false
I, [2010-09-24T14:14:41.838905 #23692] INFO – net.ssh.connection.session[1074e7c]: channel_data: 0 731b
I, [2010-09-24T14:14:41.839079 #23692] INFO – net.ssh.connection.session[1074e7c]: channel_eof: 0
I, [2010-09-24T14:14:41.839239 #23692] INFO – net.ssh.connection.session[1074e7c]: channel_close: 0
Relevant log of 5.0rc1:
I, [2010-09-24T14:16:53.719107 #23700] INFO – net.ssh.connection.session[c3b6d0]: channel_open_confirmation: 0 0 327680 32768
I, [2010-09-24T14:16:53.719187 #23700] INFO – net.ssh.connection.channel[c3b554]: sending channel request “exec”
I, [2010-09-24T14:16:53.788932 #23700] INFO – net.ssh.connection.session[c3b6d0]: channel_data: 0 379b
I, [2010-09-24T14:16:53.789546 #23700] INFO – net.ssh.connection.session[c3b6d0]: channel_request: 0 exit-status false
I, [2010-09-24T14:16:53.789813 #23700] INFO – net.ssh.connection.session[c3b6d0]: channel_close: 0
I, [2010-09-24T14:16:53.812891 #23700] INFO – net.ssh.connection.session[c3b6d0]: closing remaining channels (0 open)
The channel_success event is missing, thus net-ssh does not know when to process the response.
