SSTP error Windows 10 connection
I’ll try explain my problem with my bad english.
I am trying to connect in a RB with SSTP Server active, the client is a windows 10 desktop, but, when i try to connect, returns the following message:
Is not possible to connect to sstp-network
The message received was unexpected or badly formatted
Some considerations:
I’m not using certificate,
Forcing EAS Encriptation, MSCHAP1 and MSCHAP2 Authentication
You can not establish SSTP connection to Windows machine without certificates.
Have you some tutorial teaching how to set/ use sstp site-to-site and client-to-site with certificate on mikrotik?
Give this a try:
http://www.dr0u.com/mikrotik-setup-sstp-server-for-windows-10-client/
-tp
