Hi everyone,
I have deployed a Point-to-Point link using two MikroTik LHG 5 XL AX devices.
In our laboratory testing environment, the link was completely stable with no issues. However, since moving to the field deployment, we are experiencing frequent link drops. The log consistently shows: disconnected, not responding, signal strength -62.
Despite the signal strength appearing to be around -62 dBm, the link remains unstable. I have performed a spectral scan at the site, which shows a very clean environment in the 5GHz band with no significant interference (no overlapping signals in the selected frequency range).
Here is the current configuration of the AP:
/interface/wifi set wifi1 configuration.country=Superchannel .ssid="َAP-ST" .mode=ap set wifi1 security.authentication-types=wpa2-psk .encryption=ccmp .wps=disable set wifi1 channel.frequency=5765 .band=5ghz-ax .width=20mhz .skip-dfs-channels=all
What steps can I take to resolve the frequent disconnections?
