Static pptp server binding problem.
I configured static pptp server binding (with correct username).
Every time PPTP is reconnected it makes dynamic binding instead of using static.
It is Mikrotik-Mikrotik connection. Both sides have same ver.: 6.36.2
Upload some pictures for pptp server configuration
Hello, i have same issue but only sometimes - it happends randomly. I use Mikrotik-Mikrotik enviroment. When I manualy do disable/enabla client or remove dynamic connection it reconnect corectly.
Thank you
I tried more than one but the same problem
