Hi everyone,
I try to setup a static route for 2 Lans communication.
Now, PC2 and R2 are able to reach PC1 and R1.
But PC1 is unable to reach PC2 and R2.
And R1 is able to reach R2, not reach PC2.
In addition, I have setup Qos for both network.
Eventhough I set it off, nothing changed.
Thank you for the advice.
R1
add address=192.168.10.1/24 interface=bridge network=192.168.10.0
add address=aaa.bbb.ccc.127/24 interface=ether1 network=aaa.bbb.ccc.0
add address=aaa.bbb.ccc.128/24 interface=ether1 network=aaa.bbb.ccc.0
add address=aaa.bbb.ccc.129/24 interface=ether1 network=aaa.bbb.ccc.0
add address=aaa.bbb.ccc.130/24 interface=ether1 network=aaa.bbb.ccc.0
add address=aaa.bbb.ccc.131/24 interface=ether1 network=aaa.bbb.ccc.0
add address=aaa.bbb.ccc.132/24 interface=ether1 network=aaa.bbb.ccc.0
add address=172.16.1.1/30 interface=ether6 network=172.16.1.0
/ip firewall mangle
add action=accept chain=prerouting comment=“Mark Connection & Routing”
dst-address=192.168.10.0/24 in-interface=bridge
add action=mark-connection chain=prerouting connection-mark=no-mark
in-interface=ether6 new-connection-mark=LAN_conn passthrough=yes
dst-address=192.168.11.0/24 dst-address-type=!local in-interface=bridge
add action=mark-routing chain=prerouting connection-mark=LAN_conn
dst-address=192.168.11.0/24 in-interface=bridge new-routing-mark=to_LAN
passthrough=no
add action=mark-routing chain=output connection-mark=LAN_conn
new-routing-mark=to_LAN passthrough=no
in-interface=pppoe-out1 new-connection-mark=pppoe1_conn passthrough=yes
dst-address-type=!local in-interface=bridge new-connection-mark=
pppoe1_conn passthrough=yes src-address-list=IP_topppoe1
add action=mark-routing chain=prerouting connection-mark=pppoe1_conn
in-interface=bridge new-routing-mark=to_pppoe1 passthrough=no
add action=mark-routing chain=output connection-mark=pppoe1_conn
add action=mark-packet chain=forward comment=“QoS Full Speed”
dst-address-list=QoS-Full in-interface=pppoe-out1 new-packet-mark=
QoS-FullSpeedDown passthrough=no
add action=mark-packet chain=forward dst-address-list=QoS-Full in-interface=
pppoe-out2 new-packet-mark=QoS-FullSpeedDown passthrough=no
add action=mark-packet chain=forward new-packet-mark=QoS-FullSpeedUp
out-interface=pppoe-out1 passthrough=no src-address-list=QoS-Full
out-interface=pppoe-out2 passthrough=no src-address-list=QoS-Full
add action=mark-packet chain=forward comment=“QoS limit” dst-address-list=
QoS-limit in-interface=pppoe-out1 new-packet-mark=QoS-LimitDown75
passthrough=no
add action=mark-packet chain=forward new-packet-mark=QoS-LimitUp30
out-interface=pppoe-out1 passthrough=no src-address-list=QoS-limit
add action=masquerade chain=srcnat comment=“masq. pppoe traffic”
out-interface=pppoe-out1 src-address-list=IP_topppoe1
add action=masquerade chain=srcnat out-interface=pppoe-out2 src-address-list=
IP_topppoe12
add action=masquerade chain=srcnat comment=“NAT Loopback 192” dst-address=
192.168.10.0/24 out-interface=bridge src-address=192.168.10.0/24
add distance=10 gateway=pppoe-out1 routing-mark=to_pppoe1
add distance=1 dst-address=192.168.11.0/24 gateway=172.16.1.2 routing-mark=
to_LAN
add distance=5 gateway=aaa.bbb.ccc.254
R2
add address=192.168.11.1/24 interface=bridge network=192.168.11.0
add address=172.16.1.2/30 interface=ether6 network=172.16.1.0
add address=aaa.bbb.ccc.16/24 interface=ether1 network=aaa.bbb.ccc.0
add address=aaa.bbb.ccc.17/24 interface=ether1 network=aaa.bbb.ccc.0
add address=aaa.bbb.ccc.18/24 interface=ether1 network=aaa.bbb.ccc.0
add address=aaa.bbb.ccc.52/24 interface=ether1 network=aaa.bbb.ccc.0
add address=aaa.bbb.ccc.53/24 interface=ether1 network=aaa.bbb.ccc.0
add address=aaa.bbb.ccc.54/24 interface=ether1 network=aaa.bbb.ccc.0
add address=192.168.11.0/24 gateway=192.168.11.1
/ip firewall mangle
dst-address=192.168.10.0/24 dst-address-type=!local in-interface=bridge
dst-address=192.168.10.0/24 in-interface=bridge new-routing-mark=to_LAN
passthrough=no
passthrough=no
192.168.11.0/24 out-interface=bridge src-address=192.168.11.0/24
add distance=1 dst-address=192.168.10.0/24 gateway=172.16.1.1 routing-mark=
to_LAN
