I followed this tutorial: http://wiki.mikrotik.com/wiki/Manual:Simple_Static_Routing
I would like to configure a similar network, but with one router:
Now all PCs have access to internet.
What I am trying to achieve is PC1 and PC2 to have connection to VOIP adapter.
I did it using NAT masquerade, but based on this topic NAT should be used when it’s really needed.
In my situation I should use routes.
I tried the following, but as you can see the route is blue…
Thank you in advance for any help!
EDIT:
The device from LAN2 actually is not a regular PC, it’s a device (VOIP adapter) for which I can’t indicate the default gateway (the normal gateway for PC3 would be 192.168.3.2).
I tried everything and only Masquerading (with “Out Interface” - LAN2) will make a connection from LAN1 to LAN2.
Can anyone confirm this is the only solution for my case?
